Fuel pump wiring relay
Old Jul 13, 2013 | 12:30 PM
robbo9006's Avatar
robbo9006
Default Fuel pump wiring relay
Tried the relay wiring on the fuel pump.
The original wire is at 10v.
So I created a 12.1 v feed.
87 earth
85 with fuze to 12.1 v feed.
86 To the bosch 044 fuel pump
30 from the trigger.
I did this and the 25a fuze from the trigger near the yellow relay at the front gets hot and blows without the car working at all.
I quickly rewired it as it was wich was easy and it fired up.
Why would the 25amp fuze at the front of the car under the passenger footwell blow.
I rewired it direct to the battery and it still blew
Old Jul 13, 2013 | 12:41 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
that isn't how you wire a relay that's why you are having issues
here's an annoying american chap with an explanation
Old Jul 13, 2013 | 12:43 PM
robbo9006's Avatar
robbo9006
Good stuff.
I went on a relay site and took the instructons of there .
I will have another look .
Could you give the correct directions for now.
Ive been at this since 7.30 and got no were.
I had a view.
He does it totally different.
wow .
Have to say thankyou but the vid bloke is dire .
Well its sorted 12.2v at the pump.
I went the American way and also changed the relay.
I have lost my fuel sender on the fuel guage though unless I am on empty.
will go and fill up and report back.
Old Jul 13, 2013 | 06:48 PM
robbo9006's Avatar
robbo9006
well wish I hadn't put £15 in as I ended taking fuel tank of to get the sender wires on.
I didn't need to in hindsight but it ended up that way as I had a load of fuel in the tank.
I've emptied tank so all is safe.
I will replace it tmz and put a small amount of fuel in to test her out.
just short of 12 hrs to put an extra 2.2 volts to a fuel pump.
It was one of those electrical dayz were I tidied all I saw and put soldier on rough connections and heatshrinked a lot of stuff.
So there will be a lot of stuff that has been corrected as well.
The car is having it's stereo in tomorrow so i'm soldiering and heatshrink head tmz as well.
cossie09
Sep 14, 2015 04:21 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
