Escort cosworth - water boiling
Old Jul 7, 2013 | 07:26 PM
midnight_man's Avatar
midnight_man
Default Escort cosworth - water boiling
Hi,
problem with boiling water after 5-6 km of driving...temp gauge is about quater? No racing, just light driving about 70-90km/h, outside temperature 28°C.
When I arrived to garage, heater tank was like "balloon" and water was boiling. (temp gauge still under the quater).
When i turned off the ingnition, boiling raised! It boiled about 2 minutes.
Then I started engine, remove cap from heater tank and water is slowly rising up to the top of heater (cca 30sec up top). I saw bubbles comming out from pipe...but same bubbles I can see if I turn of the ignition so I am guessing that water is boiling inside engine (this makes bubbles) - But there is a question why is water boling inside engine? Car stays for a few years, Last year a cleand water system with 10pcs of cleaners (flush) there was a lot of "mud" in system...Any idea before I demount the thermostat and water pump?
Thanks! (sorry for my english)
Old Jul 11, 2013 | 07:21 PM
midnight_man
So the Thermostat was dead....
but I changed it...and there is still some presuure in heater tank ( and bubbles when engine is running (hot)).
How can I check up 100% if the head gasket (or head) is OK? There is no OIL in water, no Water in oil...no white smoke...
And when I turn off the engine (hot) ..water is bubble from engine to heater tank - is that normal?
Old Jul 11, 2013 | 07:31 PM
adam151082's Avatar
adam151082
Mine was doing that, there was a loose coolant hose. It only boils when its not under preasure so theres preasure escaping somewhere
prohaps shine a torch and look for steam coming out somewhere.
Old Jul 11, 2013 | 07:43 PM
midnight_man
If there will be loose hose.... = water leak...but there is no any water under the car
Old Jul 11, 2013 | 07:53 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Get one of the rad sealant chemicals as they work well on tiny leaks
Old Jul 12, 2013 | 07:47 AM
midnight_man
Maybe wrong cap?
Old Jul 12, 2013 | 08:02 AM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Originally Posted by midnight_man
Maybe wrong cap?
Could be, and cheap enough to try.
Old Jul 12, 2013 | 08:05 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
you must fit a bypass thermostat
which looks like this
Old Jul 12, 2013 | 02:40 PM
adam151082's Avatar
adam151082
Mine wasnt loosing water it just couldnt hold preasure, the pipe was loose on the expansion bottle, I only notice cos when I touched the hose bubbles went in the the bottle
Old Jul 12, 2013 | 02:46 PM
midnight_man
I changed cap of heater tank...now system is not pressuring (cap is working ) old cap was dead..... But when engine gets hot, water will blow out of the heater tank ....so I gues that head gasket is gone.....
Old Jul 13, 2013 | 05:25 PM
midnight_man
So...I found a problem...
www.wi-telecom.sk/ecus/cossie/head1.jpg
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
