no spark
Old Jul 6, 2013 | 10:56 PM
s2erst's Avatar
s2erst
Default no spark
Hi I just fitted new engine to my esc cos and now has no spark. If i put a plug in one of the leads you get a small spark when you turn on and off the ignition but nothing while cranking. pump doesn't prime unless I unplug the blue sensor on passage side of block the pump will prime but as soon as I plug it back in it stops. running out of idea's now
Old Jul 8, 2013 | 06:43 AM
midnight_man's Avatar
midnight_man
Led diagnostic?
Or check all wires from sensors to ECU ( distributor cap and crank pulley )
Do you have power on injectors while starting? (use small light bulb for test)
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
