RS Replica Wheels - Nut Problem
Old Jul 2, 2013 | 09:28 AM
Rudders666's Avatar
Rudders666
ST330 :D
Exclamation RS Replica Wheels - Nut Problem
Hi all,
Have any of you fitted RS replicas to your ST-2's at all?
I've fitted them with OE Ford nuts but they don't appear to be right. Has anyone encountered similar problems or can tell me what nuts they use?
Thanks,
Pete
Old Jul 2, 2013 | 09:32 AM
RichieST's Avatar
RichieST
What problems are you having with them?
Old Jul 2, 2013 | 09:35 AM
Rudders666's Avatar
Rudders666
ST330 :D
Getting a slight wobble through the steering. I was getting a major one after fitting them with the aftermarket nuts I already had and so swapped them out for the Ford ones but turned out the problem was a wheel bearing. Had that replaced and was fine but since getting my brakes done the wheel nuts seem to be able to be tightened all the time. I'm wondering if I need some more aftermarket ones as the Ford ones don't appear to sit right
Old Jul 2, 2013 | 11:46 AM
Rudders666's Avatar
Rudders666
ST330 :D
Might have just needed torquing up. Keep you posted
Old Jul 2, 2013 | 02:13 PM
RichieST's Avatar
RichieST
It is quite possible that you have studs that are too long for the new wheels, I know it is an issue with genuine RS wheels. If this is the case then it can crack the nut apart, damage the wheel stud or damage the wheel stud hole.
The cure is to either cut down the studs, or what I would do is get some open ended nuts, usually fitted to mondeos.
Old Jul 3, 2013 | 08:12 AM
Rudders666's Avatar
Rudders666
ST330 :D
I was advised to get these
http://www.ebay.co.uk/itm/3210311054...84.m1423.l2648
No idea whether they're right or not though. I think the Ford ones have an angle then a flat bit so the guy at the garage said I needed a fully tapered bottom as at the moment it was only gripping at two points where they angle back in
Old Jul 4, 2013 | 11:06 AM
Rudders666's Avatar
Rudders666
ST330 :D
New wheel nuts arrived today. 12Mx1.5mm cone seated. Massively better fit
JoeyBoyden
Jan 4, 2024 02:36 PM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
rst-s1
Aug 23, 2015 07:56 AM
RSMK4TURBO
Aug 19, 2015 04:46 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
