Cam just been fitted loud back fires
Piper285 cam just been fitted
Geezer adjusted the dizzy cap slightly forward past the notch!
1 full turn on bleed valve
Car now runs just up to 12psi but doesn't hold!
Straight away the tappet got stuck n it was tappen really loud! Then it unseized n sounds quiet now!
She pulls hard n lights up in 2nd under load!
Now as I come off the throttle n drop it down a gear for roundabout etc he bangs a few times really loud!!!
Is this normal?
Is this normal?
PassionFords Creator
Is this normal?
Is this normal?
So to summarise - this garage has:
- Fitted a new performance camshaft
- Advanced your ignition timing
- Turned up your boost
I assumed they fitted wideband fuel monitoring equipment and checked the AFR is safe after all that performance enhancement work?
He hasn't done that mate! He set his own rs up with advanced ignition n afr gauge was fitted in his car! He says he no what he doing!
Is it wise to get the ignition turned back to the original position! N get it set up properly
How much do u charge to set up buddy!
I'm not a mechanic! Far from it!
I don't no nothing about the workings of the engine I pay people to do it for me!!
It was my pal ho did the work on his drive way :s
He has 2rs s n he had em running well for years he sets them up his self! So I assumed he no what he was doing!
Get down to Jano at Oddkids
Yeh I'm gonna get it down there sat ! Got work now! I've placed the dizzy cap notch back to the original position directly below the notch on the head:s also woun the bleed valve back In all the way that should be ok till sat??
What's the going price on a set up these days with or without a super chip!
Alrdy have huge front mout . Cam pulley new followers exhaust swirl pot oil breather, n in the process of geting t34
Want her running nice n fast
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Red_bull
Aug 9, 2015 08:34 AM
blakey100
Aug 4, 2015 08:17 PM
