T34 turbo with cut back blades
Old May 27, 2013 | 02:15 PM
cossie891's Avatar
cossie891
Default T34 turbo with cut back blades
What is the advantages of having cut back blades what do they do
Old May 27, 2013 | 04:05 PM
Billy_RS's Avatar
Billy_RS
Pm Wilky. He knows a lot about turbos
Old May 27, 2013 | 04:15 PM
scoooby slayer's Avatar
scoooby slayer
from cutting back the blades i think it allows the turbine to flow more gas through it so there will be less resistance there, but it will be laggier as the surface area of the blade is smaller.
i may be wrong but i think thats what its for, to basically make the turbo so it can flow abit more air and make abit more power at the expensive of abit of lag.
Old May 27, 2013 | 05:02 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
It was to reduce turbine shaft speed at high boost levels the by product was increased exhaust flow and an increase in power
They were laggier obviously but were used in the early era of als
Old May 27, 2013 | 06:03 PM
cossie891's Avatar
cossie891
Ah right ok I have just got a rebuilt t34.63 with cut back blades and now the boost doesn't come in till 4.5k and it's horrible lol would a new chip and setup sort this out?
Old May 27, 2013 | 06:50 PM
cossie891's Avatar
cossie891
Would I be better selling the turbo and buying another std one?
Old May 27, 2013 | 07:03 PM
Staffi's Avatar
Staffi
I'd change the housing maybe?? Surely a .48 housing will improve spool?
H15 FSC's Avatar
H15 FSC
i think you should swap it for my T3
Old May 27, 2013 | 07:10 PM
Staffi's Avatar
Staffi
Dan,
TT Stage 2 T3 is a cracking blower bud
When mine was on the NMS Gunship live map i loved it
Old May 27, 2013 | 07:13 PM
cossie891's Avatar
cossie891
What would it be like over a std t34.63
Old May 27, 2013 | 07:15 PM
cossie891's Avatar
cossie891
I used to love my t34 untill it started to smoke bad so bought this one
Old May 27, 2013 | 07:23 PM
Staffi's Avatar
Staffi
Well obviously you're not going to make the power Of a T34.63 for starters, BUT you'll have instant respone but it will die at 6-6.5k revs.
Depends what you're after and what you want to use the car for, imo a live mapped TT Stage 2 T3 car is a great, punchy road car, but as said you'll make 310-320 max, if you want 360-390 then stay with what you have.
Hope this helps
PS, T34/48 is a great inbetweener
Old May 27, 2013 | 07:31 PM
cossie891's Avatar
cossie891
I love the punch my .63 gave me and I like a bit of lag I want 360 plus as well so I will prob sell it on and get another one or change the housing for a .48 and keep the .63 as a spare
Old May 27, 2013 | 07:33 PM
scoooby slayer
i would say it will be the best of both worlds.
with the 0.48 housing you will have the smallest housing to aid response but with the cut back blades you will have a more efficient turbine wheel to help it flow better, dare i say it may respond like a standard t34 on a 0.55 housing maybe ?
as you are now you have the potential of maximum power from the turbo but maximum lag to go with it.
Old May 27, 2013 | 07:34 PM
Staffi's Avatar
Staffi
You're hard work, all that you've posted above is what this thread is about
Leave it on then if you love your .63 and lag
Old May 27, 2013 | 07:35 PM
cossie891's Avatar
cossie891
Lol I mean I loved my old one it came in full at 3.5k that's a bit of lag this one tho is too much lag for me lol
Old May 27, 2013 | 07:37 PM
cossie891's Avatar
cossie891
Would there be any way to get this turbo to come one earlier
Old May 27, 2013 | 07:39 PM
mechanic28's Avatar
mechanic28
2 bar through a T34.55 aint bad either
Old May 27, 2013 | 07:40 PM
scoooby slayer
yes, as said above fit a 0.48 exhaust housing.
Old May 27, 2013 | 07:43 PM
cossie891's Avatar
cossie891
I mean with the .63
Old May 27, 2013 | 10:51 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
roller bearing core??
Old May 27, 2013 | 11:11 PM
MrC's Avatar
MrC
you'll just have to rev higher
Old May 28, 2013 | 07:37 AM
cossie891's Avatar
cossie891
Might just fit my old smokey one for now and sell this one on an with the money get mine rebuilt
Old May 28, 2013 | 11:27 AM
wilky's Avatar
wilky
as said the cut back blades help stop reduce over speed when restrictors were run on rally cars
Old May 28, 2013 | 03:28 PM
cossie891's Avatar
cossie891
Gonna chuck a 48 on it and sell it on I think
Old Jun 27, 2013 | 01:15 PM
wolf cosworth's Avatar
wolf cosworth
If in doubt ! Flat out !
Cut back blades were there for the high boost levels in rally cars to prevent the blades touching the turbo housing and causing all sorts of trouble.
I had on my saphire stg 2 cut back blades and it gave this all or nothing effect awesome in the dry scary " for passengers" in the rain.
Old Jun 28, 2013 | 08:23 PM
costina's Avatar
costina
Live long and prosper!!
so you have increased the size of turbo and the amount of air being produced is greater.
Hope your not running the same amount of boost.
More air = more fuel and any turbo change will require a chip change.
Fordmad!
Sep 26, 2015 05:24 PM
biggiejody
Insurance
Sep 2, 2015 12:04 PM
Bailes1992
Aug 16, 2015 07:14 PM
turbobill
Aug 9, 2015 05:21 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
