ERST breather system.
Old Mar 15, 2005 | 06:32 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default ERST breather system.
As standard, ERST breather sys plugs into the airbox like on Cossies (and most other cars) right?
Anyone got a diagram of the std ERST breather setup, and what changes when using an uprated setup?
Cheeeers
Old Mar 15, 2005 | 06:41 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Standard:
Pipe between block and top right of cam cover.
Top Left Cam Cover port into little plastic thing, then goes via big plastic pipe to meterhead. + vacuum tube to inlet
Uprated:
Block goes to bottom port on breather pot.
2 cam cover ports to the breather
And the remaining port on breather (as there is 3) goes to the meterhead.
Old Mar 15, 2005 | 06:44 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
And dont the one to the metering head suck oil thru on boost?
Old Mar 15, 2005 | 06:45 PM
PhilM's Avatar
PhilM
Block the meterhead off. And the port on the breather that did go to it, whack a breather filter on it (Or to a catch tank)
Old Mar 15, 2005 | 06:47 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
The port in the tank is extended up inside to the top so this can not happen>
Stavros's Avatar
Stavros
DEYTUKURJERBS
Aaah, thats what i thought
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
beller
Sep 21, 2015 04:13 AM
dms04
Sep 11, 2015 01:57 PM
