ST170 lambda Ford or other brand?
Old Apr 17, 2013 | 06:46 PM
LHutchin's Avatar
LHutchin
Default ST170 lambda Ford or other brand?
Hi,
I need a front lambda sensor for my ST.
Ford are a whopping £167
Does anyone know who makes them for Ford?
Are another brands, i.e. NGK just as good?
TIA
Old Apr 17, 2013 | 07:25 PM
Thrustyjust's Avatar
Thrustyjust
Buy cheap, buy twice to be honest. My daughters Polo needed a sensor and cat. Mate put an OE vw sensor and a cheapy cat on it and was fine for the 2 years we kept it.
Old Apr 18, 2013 | 07:04 AM
oldford's Avatar
oldford
The problem with modern cars is that the heater of the Oxygen sensor is monitored.
Different makes of Oxygen sensors often have different resistance in the heater.
And that will trigger a DTC again and light the EML again.
Old Apr 18, 2013 | 07:34 AM
RichieST's Avatar
RichieST
£167
I bought one from Ford about 3 years ago and it was around 50 quid. Try sending a parts request to car parts express, I buy quite a lot of genuine bits from them.
Old Apr 18, 2013 | 07:41 AM
ben_frst's Avatar
ben_frst
Originally Posted by RichieST
£167
i doubt ford make the lambda phone your local motor factors im sure they will do a good quality replacement bosch ngk or denso and it will be fine and around £50-£70
Old Apr 19, 2013 | 01:10 PM
Sp3no's Avatar
Sp3no
I fitted a Bosch one to mine and it worked perfectly fine, i thought i had bought an expensive one at £85 but £167 WTF!!
Old Apr 19, 2013 | 07:53 PM
LHutchin's Avatar
LHutchin
And £167 was discounted!
Old Apr 24, 2013 | 02:02 PM
borinous's Avatar
borinous
bought NGK £48 seems ok so far
Dahl88
Aug 22, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
