Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Mig welder advice
Old Apr 16, 2013 | 05:54 PM
Aforbes88's Avatar
Aforbes88
Default Mig welder advice
Hi guys
I'm looking to buy a welder for home use for welding little things like brackets sills exhausts ect. But I'm not looking to spend alot as il be getting used to welding again after not doing it for a long time.
Is this one any good?
http://item.mobileweb.ebay.co.uk/vie...id=86609063251
Cheers Andy
Old Apr 16, 2013 | 06:14 PM
crazycage's Avatar
crazycage
shit tbh, this one is better for not much more .
http://www.ebay.co.uk/itm/Wolf-Mig14...item3a7e294681
Old Apr 16, 2013 | 06:44 PM
Aforbes88's Avatar
Aforbes88
Ok cheers bud
Isit easier to weld with gas or isit easier with no gas?
Old Apr 17, 2013 | 03:19 PM
swiftyrs's Avatar
swiftyrs
U need a 150 or 180 amp welder for best results
gas less r crap ,
Try get 1 mm wire lead un gun , miles better than 0.8 mm as this tends 2 snag inside lead from welder 2 tip .
Use argon gas not co2 in an ideal situation .. u'll get a better weld as argon is inert ( argo shield light or universal will do for mild steel weldin )
Better 2 go for the slightly bigger amps as they r better for fine tuning wen welding , any thing smaller un welder will b set on flat out most of the time , u dunna want 2 end up with bird crap welding sittin on the 2 pieces of metal ur tryin 2 fuse 2gether , un finding u aint got no more power 2 do the job .....
Old Apr 18, 2013 | 08:43 AM
Aforbes88's Avatar
Aforbes88
Ok thanks very much for your advice much appreciated
Old Apr 18, 2013 | 11:35 AM
carl n 1977's Avatar
carl n 1977
try and find a nice second hand snap on mig had my work one 14 year and still going strong
Old Apr 18, 2013 | 12:39 PM
chalkey's Avatar
chalkey
rst junkie
ive just bought the Clarke 135te, cant recommend them enough, they weld very well
I was warned away from the wolf welders, they are cheap for a reason
I got mine with a vat free offer from machinemart
Old Apr 19, 2013 | 06:00 PM
Rax's Avatar
Rax
You can get good results if you know what you are doing with quite an inexpensive welder.I have here a clarke 90 of my mates and my 150 turbo.None mega money and am yet to have them fail.Obviously if you are using it all day you need something bigger but just for bits and bobs on panels the 90 is good enough.
Old Apr 20, 2013 | 08:10 PM
Aforbes88's Avatar
Aforbes88
Rax- thanks bud I'm going to get a mid range welder as itl last longer then
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
