Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
Focus ST2, trouble with boost pressure.
Old Mar 28, 2013 | 05:56 PM
Hansemann's Avatar
Hansemann
Default Focus ST2, trouble with boost pressure.
I was driving with my car. Then suddenly I lost boost pressure and power. DTC codes0102 , p0458, p0079, p0076, p0243,
And I looked around in the engine bay. But then I found this contact to the oil diaphragm that was broken and hanging around:Name:  IMG_20130327_230117_0.jpg
Can this have something to do with the boost pressure?
Old Mar 28, 2013 | 06:18 PM
RichieST's Avatar
RichieST
yes that will cause it! What's the white stuff around it? Has it been glued in or something?
Old Mar 28, 2013 | 06:38 PM
Hansemann's Avatar
Hansemann
yes i have tried to glue it, but it did not help... but what has it to do with the boost and power? and what does it do?
Old Mar 28, 2013 | 07:47 PM
RichieST's Avatar
RichieST
Inside the oil filter housing is a diaphragm which when it splits causes no boost, it then pressurises the crank case and can do a bit of damage. I bet all your boost is disappearing out that hole now.
Old Mar 29, 2013 | 08:25 AM
Hansemann's Avatar
Hansemann
okey thanks.. so can i take it off and try to glue it properly or what do you suggest?
Old Mar 29, 2013 | 09:41 AM
RichieST's Avatar
RichieST
Replacement is the only way to go IMO, there is oil pressure and boost pressure inside that housing so I don't think any glue will work for very long at all.
While you are at it replace the hose that goes from the housing, up behind the inlet manifold and into the cam cover. It looks like you still have the plastic hose that is very common to split and cause similar errors. Chances are it will break when you take the filter housing off. There is an updated rubber hose which is much better.
Old Mar 29, 2013 | 07:00 PM
Hansemann's Avatar
Hansemann
Okey..Do you think this is a good solution?: http://www.focusrsparts.co.uk/focus-...prod_1562.html
Old Mar 29, 2013 | 09:48 PM
Thrustyjust's Avatar
Thrustyjust
Being your from Norway, just get the standard one that fits the Volvo engine. It will be a lot cheaper and works. The new one allegedly has a better diaphragm anyway.
Old Mar 29, 2013 | 10:26 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Not cheap but it will certainly do the job. More of a performance solution but thats the one i'd go for personally. Think there was a guide in one of the Fast Ford magazines, so technically you could make your own kit up if you wanted. It uses the same housing but modified...
Old Mar 30, 2013 | 12:19 AM
Hansemann's Avatar
Hansemann
Thanks! Thats what i wanted to hear the orgiginal housing look so cheap with the plastic, and i wont it to last longer than 15 min.. I have allready ordered
Old Mar 30, 2013 | 12:56 PM
Thrustyjust
Choice is always yours, but I know cars running 300 bhp and not having any issues with the standard part. Why pay more for a part that wont make any difference ?
Old Mar 30, 2013 | 01:07 PM
RichieST's Avatar
RichieST
Don't forget there is a surcharge on the standard unit that you might not get back if your part is broken. I've not had any problems with my housing and it has been quite a good level of tune for a couple of years now!
Old Mar 31, 2013 | 06:48 PM
Hansemann's Avatar
Hansemann
Yeah i might think to build a new performance engine in the future..
i know the std one will work fine, BUT so many st and volvos having this problem it says to me it does not work good enough..
Old Apr 1, 2013 | 11:36 AM
AstoN_B's Avatar
AstoN_B
Yeah there's nothing wrong with uprating parts. The fact the kit has been it together means there are people that want it, and its not a pointless modification.
Old Apr 26, 2013 | 02:16 PM
Hansemann's Avatar
Hansemann
bad news.. i replaced the old oilfilter housing, but still same problem. No power, just a little boost.. same dtc codes... i have checked the boost solenoid,it works. and also i get the esp fail in computer. can that fuck up the brain?
Old Apr 26, 2013 | 02:53 PM
Hansemann's Avatar
Hansemann
One question: is this correct wiring for the booost solenoid?
Its a new maf sensor.
is it possible to test the map sensor?
its not orignial: i have intercooler and pumaspeed map(race plus)
Old Apr 26, 2013 | 05:59 PM
RichieST's Avatar
RichieST
no idea about the boost solenoid. Esp failure is usually due to the Maf failing, i had it recently and a new Maf cured it. Did you clear the codes after changing the filter housing?
Old Apr 26, 2013 | 07:02 PM
Hansemann's Avatar
Hansemann
yes i cleard the codes..
Old May 3, 2013 | 12:28 AM
Hansemann's Avatar
Hansemann
turns out it was fuse nr 35 for the esp system that was broken...
thanks for all answers
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
