MK 2 Mondeo Clutch Change...HELP Please
Old Mar 16, 2013 | 08:28 PM
Michael Wigg's Avatar
Michael Wigg
Default MK 2 Mondeo Clutch Change...HELP Please
I have a x plate (2000) 1.8 Mondeo which needs it's clutch changed. I need some advice.
I have the Haines manual but that's about as much use as tits on a goose.
I have no workshop so am going to have to remove the subframe and drop the transmission out the bottom.
Here's my questions.
Are there any sensible short cuts i can use to do this? I only want to change the clutch!!
Do i really need to strip the car down like the Haines manual says?
I bought the car for a few hundred, six months ago and don't want to waste a huge amount of time on it. It's a great runner apart from the clutch.
Hope someone can help...thanks in advance
Mike
Old Mar 16, 2013 | 08:38 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
The only other way I've heard of other people doing it is by dropping the subframe on the nearside and just resting the box on it while the clutch is changed but I've never done it that way myself so I couldn't tell you how difficult or easy it is to do it that way. I personally think it's more hassle than it's worth doing it that way.
They're not actually that difficult to do really, I used to do them pretty quickly.
Just a tip though, before you drop the subframe, insert a really thin screwdriver in the holes through the radiator top locating pins that go through the slam panel to stop it falling down, I've seen a few folk not do that!!
Old Mar 16, 2013 | 08:54 PM
DangerousBryan's Avatar
DangerousBryan
Hateful job. Possibility of captive nuts spinning in the floor on one that old. As said tie the radiator up at the top before you drop it. Make sure you unclip all the wires and aircon gubbins before you drop it. Might be worth getting some new pinch bolts for the ball joints before you start.
Old Mar 16, 2013 | 09:01 PM
kev 3dr's Avatar
kev 3dr
as above even on a ramp on your own on a good day can take you 7-8 hours
Old Mar 16, 2013 | 09:40 PM
saph4be's Avatar
saph4be
Pice off piss just lots to remove! Only problem is if captive nuts spin on subframe! I done then by dropping sub frame a bit and wedging gearbox and was a fumbling pain!
Old Mar 17, 2013 | 10:22 AM
Michael Wigg
Thanks for this....It looks like i'm going to have to do the same and just drop the subframe on the passenger side, do i have to unbolt everything attached to the subframe? also what was the best way to support the engine and transmission?
Mike
Old Mar 17, 2013 | 10:23 AM
Michael Wigg
Thanks for the advice ...radiator is supported by two small screwdrivers!! I'll let you know how i get on.
Old Mar 17, 2013 | 10:24 AM
Michael Wigg
It's the "lots to remove that's hacking me off at the moment...rear wheel drive next time i think!!
Thanks
Mike
Old Mar 17, 2013 | 04:23 PM
wulliegunn's Avatar
wulliegunn
for Ł150,I'd just let a mechanic with a ramp do it. Amazing how many folk try a clutch job,then after they put it all back together,sometimes hear "I cant engage any gears after changing clutch etc".Even with a ramp,my mechanic took over 5.5 hours to do mines.
kudos to ya for trying it tho
Old Mar 20, 2013 | 04:58 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
I did a clutch on a V6 Mondeo and only lowered the subframe on one side. You will need a support bar for the engine, or an engine crane. You could possibly rig something up with a hefty wooden plank, but it must be capable of supporting a lot of weight.
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
