Focus RS Rail differences?
Old Mar 12, 2013 | 02:45 PM
higgsy91's Avatar
higgsy91
Zetec Turbo Baby Yeahhhh
Default Focus RS Rail differences?
Mk1 Focus RS rail.. Is there an actual difference between this and that off a 1.8?
If so.. help me out as i need one
Old Jun 1, 2013 | 07:03 AM
Mcfarlane11's Avatar
Mcfarlane11
ModFocus
no there isn't mate, I used the standard focus 2.0 rail, the only difference is the rs uses 380cc injectors.
Old Jun 1, 2013 | 09:12 AM
pee vee's Avatar
pee vee
I think the regulator is different too.
Old Jun 1, 2013 | 10:35 AM
rsmark86's Avatar
rsmark86
Just get a fuel rail, injectors and reg off a rs as a package, job done, that's what I'm thinking of doing
Old Jun 1, 2013 | 10:42 AM
higgsy91's Avatar
higgsy91
Hmm.. I'll prob just source a regulator and TB. As far as I can see the only difference on the real it's the return pipe is all metal on the RS whereas the others go into a rubber hose..
Old Jun 1, 2013 | 11:22 AM
studabear's Avatar
studabear
A frst regulator fits the rail and is adjutable.
Old Jun 1, 2013 | 01:15 PM
rsmark86's Avatar
rsmark86
Good plan
I just need one lol, so does it fit a black top zetec rail?
Old Jun 9, 2013 | 05:34 AM
Mcfarlane11
ModFocus
to be honest what power are you after? ive been using the standard focus reg, and its making good power
Old Jun 9, 2013 | 08:34 AM
higgsy91's Avatar
higgsy91
I'm after the 300 mark. I have the ref off a 1.8 at the minute.
I always thought you needed an RS one one because it worked differently to a naturally aspirated one.
I current have a walbro 255 pushing fuel to it too if that makes things any clearer.
Old Jun 9, 2013 | 09:55 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Good plan
Yes it does.
FI regs are usually 1/1, so for every bar of boost it raises the fuel pressure a bar too, otherwise you end up with there being too much pressure acting against the injectors vs rail pressure supplying them.
For example if you had 3 bar fuel pressure and then ran 2 bar of boost you'd effectively only have 1 bar of fuel pressure without a 1/1 reg.
Old Jun 9, 2013 | 10:50 AM
Mcfarlane11
ModFocus
the zetec turbo ive got in the car at the moment (up for sale)
uses the standard 2.0 reg and was making about 275 with 1.2 bar boost with no issues at all the regulator ive been told is cabable of much more too..
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
Sep 3, 2015 10:49 AM
