my xflow clutch is 190m and 23 spline......I need to replace the clutch release bearing and so I got one off ebay...however on the box it says 20 spline......does this mean its the wrong bearing and cant be used ? if that's the case then can I separate the bearing from the carrier and put it on my old one
