Water pump failure...I think
Old Mar 10, 2013 | 09:11 PM
leebroath's Avatar
leebroath
Default Water pump failure...I think
Honestly can my problems just not stop with this car !!
Ok I'll let the last one go because it was the wire but come on, please god give it up
I'm now getting this noise -
coming from the engine bay, I've also smelt burning rubber which made me think something is wrong
The burning smell came first for the past few days, it was only tonight the car started making those strange noises
Guys can anyone help me if you have had this fixed? and by running it without getting it fixed bad??
What am I looking for cost wise?
I'm kicking myself, I just had the service done with the belts renewed
was looking at these 2 pumps:
Circoli Water PumpPart Nos.: 201590211 at £19.92 or
KWP Water PumpPart Nos.: 201590215 at £35.94
from Carparts4less
Old Mar 10, 2013 | 10:20 PM
RichieST's Avatar
RichieST
Is that your video or one that sounds similar?
Old Mar 10, 2013 | 10:22 PM
leebroath's Avatar
leebroath
One that certainly sounds like it, not as bad as the video though mate
Old Mar 10, 2013 | 10:27 PM
RichieST's Avatar
RichieST
It isn't necessarily the water pump. What you can do is get a long screwdriver, carefully put the tip on the various pumps and pulleys that you can reach and put your ear to the other end of the screwdriver. This will amplify the noise and help you pinpoint where it is coming from.
Old Mar 10, 2013 | 10:29 PM
leebroath's Avatar
leebroath
Good thinking mate, although the smell of burn and the noise
Is that not an indication that its the water pump?
Old Mar 11, 2013 | 01:11 AM
leebroath's Avatar
leebroath
Been reading about the Engine Coolant etc in the car ford manual
At least ill get a warning before anything serious might happen, if the light comes on ill stop
Let the car cool down and take it to a garage
there isn't any leaking anyway
Old Mar 11, 2013 | 02:30 AM
louis_2012's Avatar
louis_2012
If the cambelt has been changed they should have changed the waterpump too? Or at least thats usual common practice as the waterpump sits behind the cambelt.
Old Mar 11, 2013 | 05:48 AM
Paynee's Avatar
Paynee
Burning rubber smell.... Some belt slipping or worse, if the new cambelt has been over tensioned? not sure on the tensioner configuration on these so maybe auto tensioner?
Where did you have the work done, i would have it back there ASAP for them to take a look over it, dont take any chances, last thing you want is for the engine to go pop!!
Old Mar 11, 2013 | 09:20 AM
leebroath's Avatar
leebroath
Took the car back down to Carnoustie where the service and belt was done
Old Mar 12, 2013 | 10:51 PM
leebroath's Avatar
leebroath
Sorted the noise, the power steering pump was all bunged up with thick fluid, ran a few flushes
He also looked at the timing belt, he had to sort something out there too....think he had to tighten it a bit more
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
