Dead Turbo - Alhambra
51 plate Alhambra 1.9tdi 115, Loss of power, lot of blue/grey smoke (especially under load or revving), and slight noise under the bonnet. Had the RAC out to tow the car home, roadside diagnosis being turbo f*cked, how is best to confirm this? Just before pulling over, the car struggled to pull over 40 in 3rd, smoke when revved stinks of oil.
ouch
if you can get your hand to the compressor, feel for play in the compresor wheel, if you've got that much smoke i suspect there will be lots of in & out movement & latteral movement
I went out to move it up on to the garden earlier, and it was like it suddenly got very foggy lol, couldnt see for smoke.
Apart from the obvious turbo, are there any other bits I'm likely to need, ie bits likely to snap come removal?
JK12
33
Apr 26, 2021 12:09 PM
