P100 Cosworth build 4x4 (Update 17/4/14!!!)
Building this truck for my dad (rizla)
He brought cossie the other week, and got the truck Sunday
Just few pics before we start striping truck at the weekend. End result will be 4x4 cossied truck
We was going to go 2WD but we think to get the power down 4X4 and it wont be such a handfull .The truck is so solid i nearly gave up cause i thought i wont find a solid one
When you come to fit the rear beam, cut into the chassis below the old leaf spring hangers. If you box it out and down from the ladder chassis you will see the rear beam from under the tub and its a bit of an eye sore. I welded in a bit of 70x70x3mm box section to mount the diff mount/hanger and simply welded in for nuts.
Use the bump stops for the solid axle are a reference point when the tub is off to line up the drive shafts.
Estate rear trailing arms will work or coilovers because std rear dampers are miles to long.
And i take it the tub arches wont have to be made bigger the rear wheels going on are 9and a half inch dymags going on the rear and 8 on the front they was off my old 3door
each to their own but having built a 4x4 and 2wd i wouldnt go back to 4x4 as having to much fun in the 2wd hence sold the 4x4.
again anything you need help with let me no got loads of build pics.
Yeah i hear what you saying im 50/50 ok lets hear what others say as well 4x4 or 2wd opinions plz as for build pics that will be great there is a few on here who have built the trucks are right helpful Thanks to yous
and the work starts lol
i am going 4x4 partly due to having the 4x4 running gear and the other reason is i have been in my brothers 2wd sapphire and it really trys to kill you spinning up over 100mph dont get me wrong its alot of fun but if your not use to this your goin to land off the road (and in scotland its normally wet so this does not help any) , it comes down to the age old thing if you want to be sliding around go 2wd but 4x4 imo should be more controlable and better to put power down but as i said i am going 4x4 but if the gearbox dies every time i use it it will be going 2wd
Thanks mate RST my Son built it for me the restro thread is on here somewhere .Just happened to have the donor car to break into the van .Them 4i engines proper underated with a collins chip they just keep reving
It is a shame mate to break it but we got it for a good price body work could do with tidying but it drives so nice and no knocking or tapping from cold not bad considering it done 114k and i love the look of P100s
some guys on here have put the 2wd sierra to 4x4 and did not need to cut the half moons but i dont know how clos these are running , what bhp are you planning on ?
Cars running stage3 so 300bhp the car feels quicker than my old 300bhp proven FRS .Going to do cut outs to be on the safe .Breaking the Saff on the easter weekend and try to get the truck stripped before just been so busy with work but the evenings are getting lighter .Have you got more pics you can put up of all your diff mounted up .
