Celica GT4 ST205 Gravel Rally Car Build
Old Feb 16, 2013 | 11:15 AM
fezzielove's Avatar
fezzielove
Default Celica GT4 ST205 Gravel Rally Car Build
Hi been a member here for few years now, have had a few projects mostly fiestas and escorts but fancied something RWD or even better AWD and couldn't refuse a low mileage wrc my friend had for sale.
spec as current is as followed
CT20B Turbo Ceramic blade
hard piped inter cooler pipe work
huge front mount don't know brand probably ebay special
JE Forged pistons rods unknown
Electronic boost controller
factory extra 5 spokes
estimated power on this spec 300ish bhp possible more
plans for her
strip and check everything for tolerance
clean paint refurbish under body and suspension steering components
re route hard pipes and weld instead of silicon joints
remove air con system and pump
uprate all bushes
and send shell for respray
here's where shes up to
also planning to remake the rear suspension geometry like this one
Old Feb 16, 2013 | 11:27 AM
vinge87's Avatar
vinge87
Cool
Old Feb 16, 2013 | 01:57 PM
LIMITLESS's Avatar
LIMITLESS
Very nice and interesting project mate, please keep the pics coming
Old Feb 16, 2013 | 02:04 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I love a nice GT Four, will have one some day. Keep the updates coming!
Old Feb 16, 2013 | 04:37 PM
fezzielove's Avatar
fezzielove
Cheers guys, I need all the motivation I can get I always seem to lose interest as a once complete car turns into a pile of parts. Today I have been stone chipping the underside and inspecting for rust luckily I found none, although I wasn't happy with one of the sills where the rear q met the seem as it has been replaced and didn't look factory, out come the grinder and now I have a big hole hopefully Tomorow will see me purchase some cutting disks and welding wire if I can fine anyone open. There a good car these celicas lots of power excellent handling, only let down is how much they cost to keep new bottom arms for the front to for over 220 a side and that's shopping about, going to get my self on milling machine and knock sum up from a billet
Old Feb 16, 2013 | 05:10 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
you need deep pockets restoring jap cars. i spent over £28000 restoring and modifying an older rwd celica in the late 90's. i remember refurb brake calipers were over £600 from toyota in comparison to under £100 for my bmw e30 calipers. body panels were scarce and had to be souced from various main dealers around the world and cost me nearly 3 grand for a pair of doors,bonnet,front wings,rear quarters,cills and a rear hatch!
Old Feb 16, 2013 | 05:49 PM
fezzielove's Avatar
fezzielove
My pockets aren't deep that's the problem haha, so far she's not cost me much and I know what you mean about finding replacement parts I'm after new glass for the hatch as I smashed it out to prep it for paint wish I haven't now. Luckily this car doesn't need much doing in the money spending department, although some serious engine upgrades are tempting bigger turbo manifolds external gates omex ecu
fezzielove's Avatar
fezzielove
Got any pics of your celica fuzzy
Old Feb 16, 2013 | 06:10 PM
fuzzy's Avatar
fuzzy
i dont have any pics anymore. i did post them up on here a few years back but ive never been able to find them again . it was a 1985 rwd celica, the last of the sharp edged design before they went all rounded. took me 8 years to restore and in the end the engine couldnt match the looks so i had to give it a cosworth conversion to make it go well.....and go well it certainly did...straight into several lampposts at high speed while spinning out of control.
Old Feb 19, 2013 | 08:06 AM
fezzielove's Avatar
fezzielove
put a few hours in on her Sunday, something that had been bugging me was when the rear quarter was replaced a bad job had been made of joining new q to old sill. out come the angle grinder and cut away the affected area
then a template was made and transferred to steel, this was then attached using my snap on mig (its older then me and still makes a cracking bead) filed all down nicely using flap wheel and fold was recreated over the sill to look factory
a coat of stone chip was then applied as it was the only paint to hand
also stripped down the back end, off come the diff cradle which was nice and rusty
check out this weld on the diff mount
shocking
Old Feb 19, 2013 | 11:57 AM
gjh's Avatar
gjh
Looks like a good project, I'll keep an eye on it.
Old Mar 2, 2013 | 09:02 AM
fezzielove's Avatar
fezzielove
not much of a update really, stripped off all the rear suspension, diff and cradle to give the floor a coat of under seal
diff cradle looking much better minus the rust
new drop links and a fresh coat of pain on anti roll bar and i know the brake hose is going the wrong way around the suspension they need to come of for refurbish anyway.
thought i would give the inter cooler a freshen up wist i was at it.
that's about it for now just waiting on loads of parts to come from all around the world got my eye on a carbon boot tho
Old Mar 2, 2013 | 09:06 AM
LIMITLESS's Avatar
LIMITLESS
Coming on well mate
Old Mar 2, 2013 | 09:34 AM
ryan_gwa's Avatar
ryan_gwa
I had one of these a year or so back. Lovely looking car, great amount of power and the handling was fantastic. But never again, the clutch change pushed me over the edge to sell it. Plus the faff of trying to get new front wings, total joke, and some so called Celica 'specialists' should be shot.
Old Mar 2, 2013 | 01:22 PM
fezzielove's Avatar
fezzielove
the car is only going to be used at tthe weekends awhen the weather is good, yeh gearbox off can be a right nightmare mines gotta come out at some point to insect the clutch shuldnt be to big of a job, drop box and engine in one lift car over engine and split, and so fr i havent found parts hard to come by not necessary cheep but plenty available. apart from the rear windscreen i have been searching for 6 months finally found one other side of the country, and what model was it you owned? standard trim?
Old Mar 2, 2013 | 03:51 PM
ryan_gwa's Avatar
ryan_gwa
Wasnt a WRC, just a normal ST205. Althought mine was a facelifted model, different spoiler and steering wheel for some reason.
Old Mar 3, 2013 | 06:43 PM
fezzielove's Avatar
fezzielove
bought some new bits for the four
got loads more in post
first job was to swap out the leaky clutch slave cylinder check out the internals on the old one, the wrc's must be fitted with trd factory parts
treated the starter motor to a refurb
gave the downpipe some lagging in situ, what nightmare im itching like fook
gave the intercooler pipe work some lagging over the turbo
got abit arty with some card, gonna make a heat shield out of ally keep them temps down
notice this when the starter was out
its blue thats A good thing right
pic of the ct26 twinscroll
ignore the cables ties there temporary
Old Jul 31, 2013 | 08:15 PM
fezzielove's Avatar
fezzielove
Update, got a big workshop now for the celica so the pace is going to pick up, the car is now getting built to tarmac/gravel rally spec. Car has now been stripped ready for seam welding
Old Aug 1, 2013 | 05:57 AM
Lee Grout's Avatar
Lee Grout
What a cool project, love it. Great job so far.
Old Aug 1, 2013 | 06:14 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Always loved these!
good work
Old Aug 1, 2013 | 05:19 PM
gjh's Avatar
gjh
Its coming on well.
Old Aug 1, 2013 | 05:50 PM
LIMITLESS's Avatar
LIMITLESS
Coming on well mate
Old Aug 1, 2013 | 05:55 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Cool! What sort of power will you be running?
Old Aug 2, 2013 | 07:27 AM
fezzielove's Avatar
fezzielove
Going for around 450 safe bhp already got all the forged bits and hybrid twin scroll, engine mods ontop of what I already have will be motec management to make use of the water injection, hardpiped intercooler pipework and side feed inlet manifold. Dearest part of the build is going to be the suspension have got a rough quote from ohlins of around 4000
Old Aug 7, 2013 | 10:13 PM
fezzielove's Avatar
fezzielove
Ok will let the pictures do the talking
cars now ready for the spit, for the underside to be cleaned ready for stitch welding
Old Aug 18, 2013 | 07:51 AM
fezzielove's Avatar
fezzielove
Ok update time, built.a spit.for the car to make seam welding easier
Old Aug 18, 2013 | 05:08 PM
gjh's Avatar
gjh
Nice work!
Old Nov 18, 2013 | 07:42 PM
fezzielove's Avatar
fezzielove
ok time for a update, seam welding is all finished floor and arches and engine bay all painted, engine has been fitted temporary for mock up of new inter cooler pipework and exhaust pipework
JoeyBoyden
Jan 4, 2024 02:36 PM
matman
Sep 9, 2015 05:45 PM
Sultzi
12
Aug 16, 2015 01:08 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
