Newbie needing help.
Hey guys and girls.
Just last month I began the lengthy and unending road of modifying my MK5 fiesta (pics to follow), when I made an unbelievably stupid mistake buying pigtail rear springs (this is what happens when you don't read eBay descriptions properly..
Can anyone help with this mistake? Kinda costly considering i'm only on apprentice wages, spending half my weekly pay on them.
Anyway, heres a picture of it as it stands so far..
Got Mondeo wheels.. trying a Euro look, something different..ish.
Posted to this thread as hoping for some other ideas.. but mainly wanna stop the damn rubbing from the back!
Thanks for any type of reply in advance!
Thinking I need a subtle kit to make it look that much lower too. Any ideas from anyone?
Sonds like you've got mk6 springs. If you've fitted them its VERY dangerous.
Got on www.zsoc.com
Buy some correct used springs
Got on www.zsoc.com
you bought the wrong springs and you still fitted them?
need changing asap, and if the wheels are rubbing on the strut mount, the springs arnt going to do anything as the wheel will still be in the same place as the strut mount doesnt move
so you need to change tyre size or get another set of wheels with a better offset to push it away from the strut, or you could use wheel spacers
Got on www.zsoc.com
Got on www.zsoc.com
Cheers for the link. shall take a look in the morning.
Oh and fyi, didn't realise they were wrong until I did research. Was only iffy to me after the back went lower than the front. Then found they are for the fork type strut used on earlier fiestas. Contemplated changing the rear axle, but then I thought to myself that would be absolutely stupid. Lol.
Thanks for the advice.
Just a little update. Measured out how much each axle can be spaced.
Quick question though, does anyone know if you can use standard spacers on the rear or do you use the axle spacers? Found two types on eBay so kinda confused.
And what are the rules on spacing? Am I not allowed to protrude out of any part of the arch or just the outer most part?
One more thing, does anyone know what's going on with ZSOC? I've registered, haven't received confirmation, mailed administrators.. nothing..
Or if anyone is selling springs near my area on here, that would be fannytastic!
Cheers.
Cheers.
