Foucs wont start ...
Drop 300 miles yesterday with no problem , got in this morning and it just turns over. The pump is not priming and there is no fuel to the rail ....
Dame thing need it for work Monday , ive checked fuses and relay all good ?????
Check the electrical pin on top of your fuel sender/pump.
My mam n dad had a 51reg 1.6 16v focus that did this.Dropped the tank down and found the pin corroed and snapped off.
My focus Rs mk 1 has just had exact same problems !!!
Plug on top of fuel pump was melted ,and pump fooked!!
I believe the pumps pack up , they draw toomuch current and melt the plug and pump !!!
Good luck mate
Good luck mate
My dads 53 plate done this last week , drove off went for a walk ,no start
I checked it all out first Make sure fuel cut of switch drivers Kick panel has,nt been triggered
Hs pump had died as it was a 2 door exhaust and tank had to be dropped nightmare
4 door can be done from inside car !
If you can put a current meter in circuit you can see what is going on. my walbro escort cosworth in-tank pump draws 4.7 amps.
you can get these meters from Maplin for Ł10.
if the immobiliser has cut in it won't crank at all so i don't think it will be that. Get someone to give the bottom of the tank a good hard thump while turning it over.
There is a red light above the radio this is on while cranking , it flashes when the central locking has been set. Will check to see if there is any power to the pump when cranking later.
Were in the footwell is the switch n/s or o/s ?
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
