Is there a big difference between a bolt in cage and welded
Old Jan 26, 2013 | 01:58 PM
romfordrst88's Avatar
romfordrst88
Default Is there a big difference between a bolt in cage and welded
I can do ever roll cage one is a lot cheaper I no and will leave me with more cash for other parts,does it do anything to the handling have a welded cage?
Old Jan 26, 2013 | 02:06 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
obvioulsy the welded in cage will be stronger as it then becomes part of the structure of the car,the bolt in one may flex unless you also bolt it to the A and B pillars which will help.both will save you from a roll its depends on what you intend to do in the car and the level of protection you want
Old Jan 26, 2013 | 02:31 PM
romfordrst88
Track days is wht it's mainly gonna be used for
Old Jan 26, 2013 | 03:31 PM
dojj's Avatar
dojj
Resident Wrestling Legend
a bolt in cage will obviously be easier to fit/remove whereas a welded one is going to be in there for the duration
on the other hand, if you weld it in wrong, you can't just drill another hole in the floor
a lot of cages now i've seen have "gusset's" welded along the a piller's as this is where you will need the most protection
Old Jan 26, 2013 | 03:44 PM
romfordrst88
I'm not gonna sell the car at any point and I don't intend on rolling it lol, it had a bolt in cage before I bought the shell so it's ready for one to go straight in and would be a quicker way of getting on the road and like u said could just use a few gussets to strengthen it
Old Jan 26, 2013 | 03:54 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i had a bolt in cage in my xr2, it really tightened the car up.
however i would go back and use gussets in the a and b pillars as i could see the flex between shell and cage.
Old Jan 26, 2013 | 04:12 PM
fordrallycar's Avatar
fordrallycar
I have a bolt in one in mine but iam changing it for a full weld in one so i can have it fixed to the a/b pillers
Old Jan 26, 2013 | 04:43 PM
dojj's Avatar
dojj
you may be able to weld the bolt in cage to the floor where it bolts is yes?
or no?
Old Jan 26, 2013 | 04:47 PM
romfordrst88
Yer can do tht
Old Jan 26, 2013 | 05:17 PM
dingla rs's Avatar
dingla rs
or no?
no they flexi to much hole reason they bolt in .go for a weld in cage if your keeping it and heavy track use
borboyous
Aug 22, 2015 11:17 AM
A.t.p
Aug 15, 2015 11:37 AM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
