Ford XR Parts For Sale Only Ford XR parts for sale in here please. Starting a topic requires you to have purchased a gold membership.
breaking xr2 zt, brembos, clears, polybushed, closures etc.
Old Jan 24, 2013 | 08:14 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Default breaking xr2 zt, brembos, clears, polybushed, closures etc.
last remaining parts from the xr2, shame to break, but hey ho.
just need to clear out before i get ideas on the shell lol!
starter for mtx75 from st170 £40
megasquirt II v3.0, setup for wasted spark, is ready for 4 COP's, cam phase sensor circuit, launch control, iscv control. had been checked over last year by James murray and given a clean bill of health. will include home made loom for zetec turbo, no issues with interference, very stable tps and cps signals.
will also include a serial cable and usb to serial adaptor that works a treat.
£430
jvc kd-avx2 head unit with ipod interface, remote and case all there £100
vibe twin 12" sub woofers in enclosure, bit of scuffing to box £100
vibe monoblock 4 amp, peak at 2800watts @1ohm £140
3 farad power capacitor £40
splx 1000watt four way amp £50
vibe se k series 6x9's in black carpeted parcel shelf made from 18mm plywood, with hinges and lifting rubbers £80
vibe slick 40 4" door speakers £30
all the above ICE can be done in a deal along with cabling and surround for boot install as mine is laid out for £450
ERST recaro front seats, good condition, rear bench and backs retrimmed to match, all in 88 spec, ready to fit to your mk2 £200
momo steering wheel, very good condition, with boss for fiesta and snap off boss £120
xr2 rad, standard with erst fan fitted (modified to make it 5mm slimmer) £50
OMP strut brace modified to clear bigger inlets £45
big brake conversion, frs 4 pot brembo callipers, 324mm discs and ferrodo pads, complete with brackets and braided flexy hoses £220
mk2 fiesta clears all round, little grubby but will clean, will include all bulbs including led brake/tail that won't fade £100
mk2 fiesta very good condition lucas headlights £30
mk2 fiesta adjustable pan hard rod, not insitu adjustable so £35
xr2 anti roll bar setup £50
xr2 bumpers painted with halfords bumper paint recently £40 front, £30 rear
**the front has been cut about to fit a front mount, you would have to look carefully to see where when fitted though**
r+b motorsport act meter, blue backlight, needs repairing, so will send off as soon as stripped so will be in perfect working order £30
various autogauge gauges: boost psi and voltage, smoked effect so can't see till lit up as in my thread, £10 a pop.
universal electric window kit, works as it should £30
Turbosmart Kompact dump valve, will come with fitting kit for frs, adjustable £50
turbo oil line filter £15
63mm dump valve take off, £5
8mm silicone megaleads HT leads for cvh with dizzy, missing king lead sadly £10
xr2 cluster plugs £6
chromed strut tops, £10 bit of rust where water collects under nuts.
renault clio rear wiper (thinner one) £20
xr2 tiebars with all bracketing and polybushed £50
xr2 fuel tank, good condition it has a slightly larger fuel return fitted to reduce back pressure in external swirl pot setups £30
xr2 steering rack in good order, rod ends are only a year old and in GWO £40
complete lockset, one key does all, will include a brand new genuine ford blank key ready for cutting £50
good condition tailgate in diamond white, would benefit from a fresh coat of paint, complete with glass (tinted or clear) £40
tailgate glass in seal tinted or clear dependant on the above) £20
front doors, needing attention, drivers side has a dent in the crease, some surface rust coming through.
they have solednoids fitted for central locking and have motors from a universal electric window kit fitted (can be removed easily though). £40 a pop
windscreen, tinted with top tint, few minor stone chips complete with good seal £40
sunroof in very good order, was brand new about three years ago £20
rear side quarter window glass in seals (badly tinted years back will remove) £30
bosch dizzy, had new rotor cap and rotor arm fitted, in great condition and works perfectly £20
xr2 rear axle complete with poly bushed trailing arms, drums replaced a few years back and still as new internally with barely used shoes and both brake cylinders replaced last year IIRC, braided brake lines and studs fitted to drums (can be removed easily enough though), handbrake cable included and is only a couple of years old and works perfectly. £80
the shell is available, been catC a couple of years back, but rebuilt and passed three MOT's since, inner wing has cut out for mtx box and mount for direct fitment of said box. clutch master cylinder is there for use with focus fluid lines, fuel pipes fitted for external swirl pot, but can easily be changed back. standard fuel tank, polybushed anti-roll bar and trailing arms, tie-bars are with car still and poly bushed.
to make rolling would need some parts, these would include suspension (front and rear struts and front springs including top cups and bearings), tca's and front hubs.
front brakes and servo not in place but rears are in tip top condition and have braided lines fitted.
body is in fair condition, ideally needing full respray and a couple of minor issues in regard to dents and surface rust.
glass is all present and windscreen was new three/four years ago, although this has had a few chips but nothing of concern.
interior is available in the most part, as are lights etc.
there is an additional fuse box for extra items and has a meta system alarm fitted with central locking and that all works fine too.
this is open to offers as i haven't fully decided what to do with it, but if i end up moving house then i will need to get it moved on.
the above parts listed with the shell will be offered to the buyer first, if a majority of the items listed sell, then it may end up a bare shell.
escort cab mk3/4 tonneau cover in grey not ripped or torn, some of the plastic corner bits are cracked though £40
thanks,
sean
p.s. drop me a text on 07800760221 if you want to talk more, i won't be able answer calls most of the time, but can with a text.
all payments to sgard99@hotmail.com
Old Jan 27, 2013 | 10:54 AM
Are the front wheel arch parts of the kit and front valance for sale
Old Jan 28, 2013 | 07:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i was going to keep the kit with the car, then try to sell as a solid shell.
depends what you're offering though i guess...
Old Jan 29, 2013 | 06:59 PM
have now sourced the parts
Old Jan 31, 2013 | 02:19 PM
studabear's Avatar
studabear
Did the cage sell?
Also have you got a offside standard xr2 driveshaft?
Old Jan 31, 2013 | 10:44 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
cage gone, shafts were custom and sold onto dean for his mk2.
Old Jun 24, 2013 | 04:31 PM
bestlownotes's Avatar
bestlownotes
Do you still have the brembos?
Old Jun 25, 2013 | 10:47 AM
Dan F's Avatar
Dan F
Still got the rad Sean?
Old Jun 26, 2013 | 06:14 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i still have them.
dan, still got the rad and fan setup, still interested?
not done anything with this for a while, need a couple of days to get the rest stripped now.
Old Jul 1, 2013 | 06:22 PM
Dan F's Avatar
Dan F
yes mate very interested
whats your best price posted please?
Old Jul 1, 2013 | 06:54 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Any idea what size wheels the Brembos will fit under bud?
Old Jul 3, 2013 | 08:51 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i changed price on xrtwo.com so £40 plus post, will do it for £45 posted.
brembos fit under 16" rota competitions, i think i had 380mm to play with on the inside of the rim. i didn't make any notes but it was bloody tight under them with wheel weights being where they were.
Old Jul 4, 2013 | 03:17 PM
Dan F's Avatar
Dan F
that's cool could you send me your pay pal and i'll get the funds sent
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
mondeomark
Sep 28, 2015 06:28 AM
