Cossie Engine Breathing
Old Jan 17, 2013 | 08:13 PM
PIO's Avatar
PIO
Default Cossie Engine Breathing
Hi Folks,
Quick one, Stage 3 engine, can you have the engine breathing TOO much?
Currently breathing from both sides of the block, should i breath from the cam cover as well ?
Thanks
Old Jan 19, 2013 | 09:59 AM
LHD220Turbo's Avatar
LHD220Turbo
most set ups ive seen always breath from the back of the cam cover, inlet side
if you look at the underside of the cover it has a section ready for you to drill out
Old Jan 19, 2013 | 10:12 AM
anglia105e hinson's Avatar
anglia105e hinson
Yeah that is true about the cam cover but......................
If you return it to the block on the other side below the turbo, it will be ABOVE the oil line which is no good because the engine will naturally try to breath out it.
How he is doing it is perfect as he is breathing from both sides and oil is returning back to sump returning BELOW oil line .
I am doing actually this on my 4x4 and it is working fine
Luke
Old Jan 19, 2013 | 10:48 AM
LHD220Turbo
yeah, always best to return to below oil level, most people put/weld a union joint near the sump plug or on the exhaust side
Old Jan 19, 2013 | 11:22 AM
cossie891's Avatar
cossie891
How about mine I have 1 going to the block under the inlet and 1 going to a fitting on te exhaust side in the block then 1 vent to atmosphere
Old Jan 19, 2013 | 11:46 AM
LHD220Turbo
as said above mate, ideally need to return to below oil level
Old Jan 19, 2013 | 02:29 PM
cossie891's Avatar
cossie891
Will I be ok with just the 2 ports for breathing?
Oct 9, 2015 07:38 PM
Gadget
Aug 26, 2015 01:02 AM
kosienutter
31
Aug 22, 2015 09:55 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
