Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
mk1 fiesta engine change
Old Jan 14, 2013 | 04:44 PM
scottie121's Avatar
scottie121
Default mk1 fiesta engine change
hi im changing the engine in my mk1 fiesta from a 957cc to a 1600 cross flow ive got the chance in buying one from a mk1 escort will it fit in as ive read on the net there mixed responce about it fitting can anyone help me out with some info many thanks
Old Jan 14, 2013 | 05:49 PM
the_frozen_one's Avatar
the_frozen_one
See your other post
Old Jan 14, 2013 | 06:24 PM
m4tt274's Avatar
m4tt274
in a word, 'no'
The block is different, the escort being rwd mounts on the sides of the block, the fiesta mounts on a cradle and beside the thermostat housing.
When you do eventually find a fiesta xr2 xflow, you will need the xr2 crossmember and driveshafts also as the 1.6 711m xflow is about an inch longer than the 0.9/1.1 Valencia engine you have.
Old Jan 14, 2013 | 07:02 PM
scottie121's Avatar
scottie121
ok thanks for the help bit of a shame as its a full race 711 engine didnt know if there was some way because some people told me it would fit thats why i asked
Old Jan 14, 2013 | 07:10 PM
m4tt274's Avatar
m4tt274
the internals will fit into an xr2 xlow. If you want to buy the engine you can get an xr2 xflow block for probably less than Ł40.
Old Jan 14, 2013 | 07:26 PM
scottie121's Avatar
scottie121
is the escort engine longer then the xr2 711 engine? or is it just because its missing the mount by the thermostat?
Old Jan 15, 2013 | 08:24 AM
m4tt274's Avatar
m4tt274
i haven't measured them so i couldn't tell you, but i'm pretty sure they are the same just different mounts.
Old Feb 18, 2013 | 10:11 PM
INOV8's Avatar
INOV8
carinnovation
The head will be worth having and should fit and if race spec should be big valve but make sure it is a late engine with a flat head or will mess up compression ratio also it may have the unleaded seats which would be a bonus even the xr2 x-flow will be for leaded may save some money in long run
Old Mar 4, 2013 | 03:34 PM
BLU's Avatar
BLU
BLU is the new black :)
Its the crank thats different. A shorter one was used in a fwd Kent engine so it would fit between the chassis rails.
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
