ST 170 leaking by pedal
Old Jan 13, 2013 | 06:27 PM
xr3-keith's Avatar
xr3-keith
Default ST 170 leaking by pedal
Hi any help here will be great
The wife's ST170 seem to have a leak coming from around the clutch pedal, can anyone help as to what it is,
http://i5.photobucket.com/albums/y17....png%5B/IMG%5D
Thanks
Old Jan 13, 2013 | 07:48 PM
Cosnada's Avatar
Cosnada
Clutch master cylinder has gone mate - very comon on Focus. Fairly cheap to buy and a little fiddley to fit - 2 hours tops if ya have never done one before.
Don't loose the clips!
Old Jan 13, 2013 | 08:04 PM
xr3-keith's Avatar
xr3-keith
Does this share the brake fulid ? As that looks a bit low
xr3-keith's Avatar
xr3-keith
Thanks
Old Jan 13, 2013 | 08:17 PM
Cosnada's Avatar
Cosnada
Yes it does but clutch supply is lost but there is a reserve for brakes. I don't like the system but you will not have a brake issue even when clutch has been lost due to fluid level take offs.
Old Jan 13, 2013 | 08:27 PM
xr3-keith's Avatar
xr3-keith
Cool thanks for the advice
Old Jan 13, 2013 | 08:32 PM
Cosnada's Avatar
Cosnada
Are you Essex way? Can assist if you get stuck.
Old Jan 23, 2013 | 12:35 PM
khanny1's Avatar
khanny1
i recently changed a steering rack on mine and theres a plastic cup with foam round it to seal where the steering coloum goes to the rack, could be that.
timsrs
Nov 13, 2018 11:48 AM
massivewangers
30
Oct 1, 2015 07:40 PM
Fudgey
21
Sep 30, 2015 06:19 PM
IainRS1700T
Sep 25, 2015 06:44 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
