1.8 diesel engine swaps and compatibility
Old Jan 2, 2013 | 01:49 AM
PETEDUDE007's Avatar
PETEDUDE007
Default 1.8 diesel engine swaps and compatibility
I have a mk6 escort van 75d with an endura de engine
I am replacing this because it's had it and I have came across a 1.8 d mk4 1990 escort with low mileage in my area and want to know if it's a straight forward swap to fit this engine into my van as far as the loom goes etc like is it plug n play as I don't want to go to too much effort?
Old Jan 2, 2013 | 04:50 PM
Colin_P's Avatar
Colin_P
The old non turbo 1.8 only needs a power feed for the fuel shut off solenoid so it should be very easy.
Other than that you obviously have the starter motor feed and water temp and oil pressure sensor feeds.
Old Jan 2, 2013 | 05:31 PM
cossiejay's Avatar
cossiejay
its easy a couple of years back I put a 1.8td into my brothers escort 55 diesel van and it was easy but I did end up fitting the front fogs,cenrtral locking,and electric windows for him
Old Jan 2, 2013 | 11:14 PM
PETEDUDE007
So the 1.8 d from a mk4 should without hassle apart from a feed required for the fuel shut off
JoeyBoyden
Jan 4, 2024 02:36 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
taylora1409
Aug 12, 2015 12:06 PM
knight19770
Aug 4, 2015 12:36 PM
vdubo7
Aug 2, 2015 08:17 PM
