Ford Range This section is for other models in the Ford range.
2.9 Granada auto box using a lot of oil
Old Dec 28, 2012 | 04:23 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Default 2.9 Granada auto box using a lot of oil
A neighbour has a 1990 2.9 auto Granada. It runs fine and the auto box is working OK. It is using about two pints of trans fluid a week. It doesn't appear to be leaking as there are never any puddles under the car. Any ideas?
Old Dec 30, 2012 | 10:46 AM
ob1marty's Avatar
ob1marty
is it smoking i think there is a valve between the box and inlet manifold that are connected they go faulty and it sucks oil from box and burns it throu inlet
Old Dec 30, 2012 | 11:01 AM
YOREVOL's Avatar
YOREVOL
YOREVOL
might be the cooler thats in the radiator, but you normally get emulsified oil in the gearbox.
Old Dec 30, 2012 | 02:41 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
He's been told the torque converter is burning it. I can't see this as that would surely produce soot and clog everything up. I'll suggest the breather to inlet manifold valve, I didn't know they had one.
Old Dec 31, 2012 | 12:10 PM
mk22door's Avatar
mk22door
Fart of the Purniture
You should ask stixy on the FSOC, if you havent already.
mk22door
49
Mar 26, 2022 07:15 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
Red_bull
Aug 25, 2015 06:27 PM
Archiejay
Aug 12, 2015 12:07 PM
