👀Sierra sapphire cosworth 4x4 Full restoration shell dip 😀
Old Dec 15, 2012 | 08:40 PM
Sierra'R'us's Avatar
Sierra'R'us
Cool 👀Sierra sapphire cosworth 4x4 Full restoration shell dip 😀
I am in the middle of a full restoration of my j reg ebony black cosworth I've had the car aside dipped by a company called SPL in Dudley West Midlands then I cud see the full extent of the work that needed to be dun and I can tell you that aside dus not hang about there is not one bit of paint left or under seal left at all jus bear metal when I got the car home it was in need of 2 new rear quoters 2new shassylegs where the beam bolts up front both jacking point areas Inner arches both sides new boot floor drivers side tunnel both Back sections of the drivers side and passengers side sill arrears where the sill meets the rear quoter behind the back bumper rear valence so fair I have dun most of the work but there is still a long way to go here's a couple of pitchers so fair
Attached Thumbnails 👀Sierra sapphire cosworth 4x4  Full restoration shell dip 😀-image.jpg
Old Dec 15, 2012 | 09:54 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
wouldnt mind gettin mine dipped and start again
Old Dec 15, 2012 | 09:59 PM
Sierra'R'us
I no mate but its a big job but well worth it
Old Dec 15, 2012 | 10:04 PM
SMILER258's Avatar
SMILER258
Looks good. I just don't like the idea of rust creeping back from panel seams
Old Dec 15, 2012 | 10:22 PM
Sierra'R'us
Ones all the welding is done it will be going back agen to be dipped then e coted Then rust won't come back e cote gets everywhere mate in all the seams and voids
Old Dec 15, 2012 | 10:38 PM
andy130's Avatar
andy130
how much is the coating costing you mate if you done mind me asking?
Old Dec 16, 2012 | 09:15 AM
adam151082's Avatar
adam151082
Sounds good, I enjoyed reading that with your spelling.
Old Dec 16, 2012 | 09:51 AM
costina's Avatar
costina
Live long and prosper!!
Incorrect where i work have had shell dipped and e coated by SPL and the e coat dont get between seams. Prior to that i worked for Honda and that process has the same issues which is why they use galvanized steel and seal prior to spot welding panels together.
But to be fair its the best solution and your doing a great job saving another saff
Old Dec 16, 2012 | 03:20 PM
Sierra'R'us
Thanks that's my plan not to see another one scrap
Old Dec 16, 2012 | 03:29 PM
costina's Avatar
costina
good man more pictures would be great
Old Jun 2, 2013 | 09:22 PM
Sierra'R'us
New pitcher
Old Jun 2, 2013 | 09:28 PM
Sierra'R'us
And moor
Old Jun 3, 2013 | 06:16 PM
SMILER258's Avatar
SMILER258
Brill work. Homemade jacking points in a new position? I mean the little cricle stump
Old Jun 3, 2013 | 07:17 PM
cossiestu's Avatar
cossiestu
Nice one! No short cuts done on that!!
Good luck with it all....
Old Jun 3, 2013 | 09:45 PM
Sierra'R'us
Thanks mate it's been proper hard work will put moor pitcher on soon
charliecosworth
Aug 19, 2015 02:00 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
cossie4x4
Aug 14, 2015 06:29 PM
pegaz
Aug 12, 2015 07:30 AM
Old ford
Jul 31, 2015 06:50 AM
