Boost control on escos (p8 ecu)
Old Dec 14, 2012 | 06:20 AM
Rollinz's Avatar
Rollinz
Default Boost control on escos (p8 ecu)
Hi guys, on my escos, i have no boost control......
In saying this what i mean is its just running direct, with a forge actuator,
Its a group N engine but surly this isnt how they ran in rallies?? And somone in the past has either removed the air injectors or amal valve???!?!?
It runs safe... No det, fueling a bit rich but nothing major,
But i would prefer propper control on there.... Whos best to speak to regarding it?
And also my car makes 2bar of boost by 2500rpm, then tails off till 4k rpm i have just less than 1 bar, then keeps tailing off more,
Now this is how a rally engine should be, so not worried about that...
But when i use the anti-lag the boost doesnt quite reach 2bar....
Altho the car is quicker cause of less lag and instant boost i just thought it should still hit 2bar especially if there is no boost control....
Does that make sense??
Any help apreciated guys :tops:
Old Dec 14, 2012 | 07:49 PM
GARETH T's Avatar
GARETH T
So there is a pipe coming straight fom our compressor house straight to your actuator ?
Old Dec 14, 2012 | 07:51 PM
Rollinz's Avatar
Rollinz
Ye mate,
Running direct as its know...?? Or how ive heard of it for many years,
Use to run my rs turbo like this 10 years ago...
Old Dec 15, 2012 | 10:24 AM
GARETH T's Avatar
GARETH T
Get it to a tuner to have a boost control solenoid fitted back on it! You'll find it's a better car after
Old Dec 18, 2012 | 10:22 AM
zvh's Avatar
zvh
i run a p8 and als on my s2 rs turbo and use a pierburg boost solenoid which are around the £60 mark this allows u to map the boost though the ecu on the p8 tommy feild uses them on allot of rally cars , works spot on no issues
Old Dec 21, 2012 | 09:53 AM
tushar897's Avatar
tushar897
A boost controller is a device to control the boost level produced in the intake manifold of a turbocharged or supercharged engine by affecting the air pressure delivered to the pneumatic and mechanical wastegate actuator. A boost controller can be a simple manual control which can be easily fabricated, or it may be included as part of the engine management computer in a factory turbocharged car, or an aftermarket electronic boost controller such as those made by GReddy.
website templates
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
JK12
33
Apr 26, 2021 12:09 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
markk
Sep 9, 2015 08:11 AM
