fuel line size
Old Dec 3, 2012 | 06:38 PM
mark r's Avatar
mark r
Default fuel line size
hello all ,im wanting to replacing fuel lines with some braided ones and i want to know what size to purchase
thanks mark
Old Dec 3, 2012 | 06:56 PM
cozzy jeff's Avatar
cozzy jeff
From fuel pump to fuel rail then return to tank -6 will be fine
Old Dec 3, 2012 | 07:08 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Mine is -12 from tank to pump then -8 pump to rail then -6 return iver end of the rail to the reg (my rail is centre feed) then -6 from the reg to the tank
Old Dec 3, 2012 | 07:23 PM
mark r's Avatar
mark r
thanks peeps both 6 or 8 mm fine and from lift pump(standard cossie pump) to swirl pot and pot to 044 pump to rail.will 8mm be ok to supply everything?
Old Dec 3, 2012 | 08:22 PM
cozzy jeff's Avatar
cozzy jeff
-6 hose is 8mm inside diameter
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
1300gt
Sep 7, 2015 12:06 PM
jonjg
Sep 1, 2015 03:46 PM
muffster
Aug 12, 2015 08:14 PM
