lightend fly problem st170
Old Nov 29, 2012 | 05:48 PM
deanhanmore-st170's Avatar
deanhanmore-st170
Default lightend fly problem st170
hi there i need some help.. im at my wits end! i got a padal clutch an lightend flywheel for my st170 from som1 on hear, its from .cfm so it says its for a svt/st170 all fits an evrything but an start up it give off a horrible ring gear noise, sounds like the ring gear an the starter motor gear dont match up :-s however once the car is running evrything els is fine.. its just on start up. took the flywheel back out and it looks like the gears are to close? has any one herd of this problem befor ? was alos thinking of bying a svt starter motor, maybve the ring gear is diffrent to the uk one? cant work it out.
Old Dec 7, 2012 | 12:43 PM
borinous's Avatar
borinous
maybe contact cfm? if it is for the svt and not the 170 (you'd think they are common but knowing ford they are different)
If they confirm they are common then maybe there is another issue?
Old Dec 7, 2012 | 01:17 PM
Sp3no's Avatar
Sp3no
You sure that your Starter motor is not at fault. There should not be a difference between the SVT and ST170. I had a SVT lightened fly fitted to my ST170 with no problems at all. If your starter is not disengaging enough it may be making the noise you describe. The starter motors are prone to problems on the ST170 as they sit quite close to the cat and get very hot
Old Dec 22, 2012 | 11:47 AM
deanhanmore-st170
yeh... we tryed a new starter but still the same.... i did e-mail cfm but they never got back to me.
Old Jan 6, 2013 | 07:28 PM
minder's Avatar
minder
stick the standard dmf back on mate with the standard clutch sts don't like after
market flywheels and clutches
Old Jan 6, 2013 | 07:53 PM
MJ_RST's Avatar
MJ_RST
No need to go back to the dmf just fit a solid 2.0 zetec flywheel
Old Jan 20, 2013 | 02:06 AM
fezzy2l16vt's Avatar
fezzy2l16vt
Put a Helix Autosport Flywheel, Clutch and pressure plate on, (full kit) brilliant setup no issues and done a few races with it to & still going strong. DMF weight 26lb Helix 11.4lbs, goes like a train.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
pie-face
Sep 15, 2015 10:43 AM
BRAM
Sep 8, 2015 07:11 AM
