mondeo tddi very low on power
Old Nov 28, 2012 | 04:21 AM
320 bhp's Avatar
320 bhp
Default mondeo tddi very low on power
got a mondeo tddi and it is like the turbo isnt working,but you can here the turbo when car is reved any idears?
Old Nov 28, 2012 | 07:25 AM
james kiely's Avatar
james kiely
is it possible you have a boost leak maybe?
Old Nov 28, 2012 | 07:27 AM
Gadget's Avatar
Gadget
Spanner monkey
is your glo plug light on?
Old Nov 28, 2012 | 11:08 AM
DazC's Avatar
DazC
Had this before on TDDi's where there was no coil light flashing or illuminated yet the car was flat and gutless. Swapped the injectors and it was fine again.
I'd have thought a boost leak would bring on the coil light and produce a fault code relating to either inlet manifold pressure or airflow upper threshold exceeded.
Old Nov 28, 2012 | 11:28 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
A boost leak won't bring on any warning lights.
Old Nov 28, 2012 | 06:13 PM
320 bhp's Avatar
320 bhp
no warning light on just very flat, but i can hear turbo when car is reved had pipe off 2nite and turbo spins free?
Old Nov 28, 2012 | 09:28 PM
james kiely
egr valve maybe gunked up
or
the air flow meter is a favourite when they go gutless.from memory if you plug this out and their is no change ,then its fooked
Old Nov 28, 2012 | 10:02 PM
saph4be's Avatar
saph4be
Wrong yes it can i seem it a few times
Old Nov 28, 2012 | 10:17 PM
steve_o's Avatar
steve_o
boost leak can put light on, most likely turbo underboost fault code or boost pressure sensor fault, as above, check all the boost hoses for splits etc.
Old Nov 28, 2012 | 11:10 PM
taycoss's Avatar
taycoss
Check boost hoses. Had one last week with split on one left hand side of bay.
Old Nov 28, 2012 | 11:14 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
seen lack of boost not put lights on and put it on, depending on driving conditions.
id start with EGR if no boost leaks personally
take some live data ideally with a good scanner
Old Nov 29, 2012 | 04:19 AM
320 bhp's Avatar
320 bhp
thanks lads
Old Nov 29, 2012 | 01:52 PM
DanW@FastFord
Spelling Club King!
On TDDI? Are you sure? On a later TDCI, maybe, but not on a TDDI, or Euro3 TDCi.
Old Nov 29, 2012 | 06:03 PM
saph4be's Avatar
saph4be
Yes positive don't believe everything you read on the net!
Old Nov 30, 2012 | 04:37 AM
M K's Avatar
M K
Had this exact problem last week on my 53 plate zetec s tdci, completely gutless and flat
Checked the hoses and the cooler to egr valve hose had a large split in it, fixed that and it's good as new again,
My coil light or engine light did not come on or flash
Old Nov 30, 2012 | 09:19 AM
DanW@FastFord
Spelling Club King!
I'm talking from personal experience, not what I've read. Where was the leak that caused the fault code, and what code came up?
Shame, I could have sold you a silicone one for a very good price!
If you fitted an OE one they can go again within a year!
Old Nov 30, 2012 | 10:34 AM
saph4be's Avatar
saph4be
How much are the silicon ones I fitted a gen ford one yesterday!
Old Nov 30, 2012 | 11:50 AM
M K's Avatar
M K
Dan - I used tape to fix it :cry
When that fails il buy a new hose, how much are they then?
Old Nov 30, 2012 | 12:10 PM
foci's Avatar
foci
I done one with eaxct same symptoms last week. It was the elbow shaped pipe going on to the right hand side of the inlet. The split was on the inside of the elbow. Very hard to spot.
Old Dec 2, 2012 | 07:34 PM
DanW@FastFord
Spelling Club King!
The pipes cost up to £90 from Ford - I sell Silicone ones for £45 - and i'll guarentee it for the life of the car!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
landaqmabba
Sep 15, 2015 07:16 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
Tank Mike
Sep 10, 2015 07:56 AM
