building engine ball bearing turbo into 2wd saph
I am building good fast road and track 2wd sapphire with:
205 block
Std. Rebuild head.
Piper cam pulleys
bd14 inlet.
Std. Exh.
2wd exhaust.
Ext. wg.
Valve cut pistons.
Std. Valve springs
Haltech E8 ecu .
Haltech coils ( wasted spark)
1000cc injectors
044 fuel pump
Std. Head. Bolts
Pace rs500 ic
This turbo could work fine in engine:
http://www.atpturbo.com/mm5/merchant...egory_Code=GTB
exhaust is ar.63 and turbine diameter is 65/56.5mm
Compresor is t04e with 57 trim.
Also i know what compresion ratio should be the best. std?
Regards
205 block
Std. Rebuild head.
Piper cam pulleys
bd14 inlet.
Std. Exh.
2wd exhaust.
Ext. wg.
Valve cut pistons.
Std. Valve springs
Haltech E8 ecu .
1000cc injectors
044 fuel pump
Std. Head. Bolts
Pace rs500 ic
Regards
rog
Sep 4, 2015 12:10 PM
muz
Aug 16, 2015 12:57 PM
