Gripper vs supra diff
Old Nov 26, 2012 | 09:09 AM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Default Gripper vs supra diff
Which ones best? Who's tried both with pro's and cons of both
Old Nov 26, 2012 | 09:30 AM
andy escos's Avatar
andy escos
afaik the gripper diff is good but the weak point is the crown wheel & pinion & when it breaks it could take out the lot so very expensive .but the supra diff is pretty much bomb proof & the turbo versions were lsd as standard .And are a bolt in conversion no welding needed at all .you can pick up second hand diffs for Ł125 delivered as well
http://www.tcbparts.co.uk/ ask for Trevor.
Old Nov 26, 2012 | 09:32 AM
andy escos's Avatar
andy escos
ps MK motorsport is making a kit to fit ,& it is all billet no welded parts so it will fit first time.
Old Nov 26, 2012 | 09:38 AM
Rsmat's Avatar
Rsmat
I'd do jag diff... After driving a gripper and not liking it mate IMO
Old Nov 26, 2012 | 09:40 AM
jpscossie's Avatar
jpscossie
3dr, R26,172 Cup, 205 GTI
I've got a Jag diff waiting to go on my 3dr
Old Nov 26, 2012 | 10:02 AM
SaphCos4x4_Dan
I've got a gripper diff which is practically brand new but I'm considering selling it and buying the supra conversion instead, hence this thread
Old Nov 26, 2012 | 10:56 AM
johnyjn's Avatar
johnyjn
Both diffs have there weaknesses , grown wheel and pinion can also be a problem on the supra diff due to the collapsible washer . But fitted with a shimmed solid washer prevents this , also the spring load on the lsd will make big difference to the torque breaking load . I'm actual going down the supra route but the diff will be rebuilt before getting used , new bearings , seals , solid washer and a kaaz super q lsd .
These diffs are over 20 years old with probable high mileage to go with that , i bet a lot of these diffs will be spinning one wheel ...lol
Old Nov 26, 2012 | 12:23 PM
BRAMMER's Avatar
BRAMMER
John do you have links to any of the companies able to supply parts for these, as said before I would like to get mine rebuilt to standard spec but solid washer
Old Nov 26, 2012 | 12:37 PM
STeve's Avatar
Super Moderator
my mates 3 dr eats gripper diffs so he is going jag route too
Old Nov 26, 2012 | 12:42 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i find it hard to be leave has has Busted a gripper diff! Do you mean he has Busted the crown wheel or pinion! I have a gripper and its a good diff I have busted 1 c.w.p but I do have around 500lb ft of torque now I have a shot peened one but don't drive like a twat so I'm confident it will be fine! Mate also has a supra one and it dosnt lock the wheels that well
Old Nov 26, 2012 | 12:44 PM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi
they are very good diffs ,but expensive proberly about Ł1500/Ł1800 by the time is fitted in the beam with shafts
mark
Old Nov 26, 2012 | 12:49 PM
STeve's Avatar
Super Moderator
I put a lot of it down to his driving style as he has had 2 in the last 2 years and both have bit the dust but he does drive like an animal, so he has gone the expensive route and only time will tell when its installed in january if it was the right decision as its in the spray shop at moment having a winter make-over
Old Nov 26, 2012 | 01:54 PM
v man's Avatar
v man
Zee Germans are coming
Any thoughts on the m5 diff in a cossie
Old Nov 26, 2012 | 02:12 PM
MK MOTORSPORT
hi
i think the supra diff seems to be the way to go ,it seems to take abuse,cheap to buy not to hard to fit and you can use your standard shafts
mark
Old Nov 26, 2012 | 02:42 PM
johnyjn's Avatar
johnyjn
Hi Chris , i did post on the last thread about a company in america about a rebuild kit . I
will have a look for the details for you .
I think the gearbox man does rebuild on these but i'm still in Europe so can't ring them .
Old Nov 26, 2012 | 02:43 PM
johnyjn's Avatar
johnyjn
Originally Posted by MK MOTORSPORT
hi
mark
Any updates on these kits Mark
Old Nov 26, 2012 | 02:47 PM
SaphCos4x4_Dan
Can we try and keep this thread on track please
Old Nov 26, 2012 | 03:06 PM
dingla rs's Avatar
dingla rs
there a beam on ebay sorted for a jag diff with shafts an everything
Old Nov 26, 2012 | 03:51 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You should be fitting a beam well before changing the diff. Not much point in fitting a strong diff if you aint got any grip. IMO the Jaguar 10" is the solution & if its Power Loc the grip obtained is incredible. Cost. beam fitted with diff & shafts was Ł1700 & the diff cost Ł20 + a Ł400 overall. Does the prop need changes with the Supra diff. The standard shafts will twist like coke cans with big power.
Old Nov 26, 2012 | 04:04 PM
MK MOTORSPORT
hi rod
you will struggle get a diff now for Ł20 more like Ł250/Ł500, no supra uses standard prop no mods just adapter same as shafts , do you think it will twist standard shafts just i never heard of it doing that
mark
Old Nov 26, 2012 | 04:36 PM
BRAMMER's Avatar
BRAMMER
Rods comments are always pointless when it comes to this site, everything his car requires has to be uprated beyond levels that most car's need.
Old Nov 26, 2012 | 04:51 PM
markk's Avatar
markk
The original jag conversion used the standard shafts, I know i had it !
I also put 6741ft/lb of torque through them with 10" wide slicks, so they can take the power. Maybe a little shy of Rods, but still healthy enough.
Old Nov 26, 2012 | 05:17 PM
MK MOTORSPORT
hi mark
which shafts because none of them will bolt straight
mark
Old Nov 26, 2012 | 05:19 PM
Rsmat's Avatar
Rsmat
Ha ha I'm refrained from saying what I want to say lol..cry:
Old Nov 26, 2012 | 05:59 PM
J1mbo's Avatar
J1mbo
B1mbo
what did you have a container boat engine?
i think supra is the way to go personally, with marks kit and the cost of a rebuilt supra diff it dosnt make much sense to go any other way.
ive got a titan plated 7.5 because i like the way i can choose my ramp angles and preload and the way it will lock when i jump on the throttle (mainly because i will be a moron) but if i do break it i want to go 9" or supra if funds are short
Old Nov 26, 2012 | 06:50 PM
markk's Avatar
markk
hi mark
mark
The standard jag 1/4 shafts had adapters welded onto the end of them.
Think torque multiplication jimbo, or do you not have gearboxes/diff ratios.
Old Nov 26, 2012 | 07:04 PM
J1mbo's Avatar
J1mbo
B1mbo
Why would you talk through torque multiplication that just makes it arkward for us to compare to other engines?
Old Nov 26, 2012 | 07:34 PM
Jay,'s Avatar
Jay,
Sponsor
Tbh gripper with a updated treated crown and pinion is all what most need there seems to be a lot of hype over the supra diff it's a big heavy dif to fit in that standard beam and the jag diff is faultless IMO spend money wisely so spend once lol
Old Nov 26, 2012 | 07:53 PM
markk's Avatar
markk
No, that gives you a real life figure as to what the components have handles, you can change the characteristics of the engines output to the road by using gear ratios.
Old Nov 26, 2012 | 07:58 PM
MK MOTORSPORT
hi ja
i thought you were a fan of the supra conversion ,the jag is far heavier and twice as much work to fit and 4 times as much money
mark
Old Nov 26, 2012 | 08:03 PM
J1mbo's Avatar
J1mbo
B1mbo
It just didn't make sense when people above are talking engine torque thats all mark but I understand why now, even though I did think you were driving a monster diesel lol
Old Nov 26, 2012 | 08:04 PM
Jay,'s Avatar
Jay,
Sponsor
I'm a fan of what works with the least bother lol I had a gripper in mine and worked brilliantly and having the crown and pinion treated works for most
With the supra diff I can't help but think it work better mounted differently but that's just my opinion
Old Nov 26, 2012 | 08:31 PM
MK MOTORSPORT
i agree with that ja
how do you think it should be mounted ,and what do you think is wrong with the way it has been mounted in the conversions already done
mark
Old Nov 26, 2012 | 11:05 PM
markk's Avatar
markk
lol, would be nice at the fly for sure
Old Nov 27, 2012 | 11:57 AM
slammed106's Avatar
slammed106
i can`t comment directly on "feel" but i do know that the crownwheel on the 106 application diff is a weak point and have seen 5 or 6 shed teeth now with only 16v 1600cc NA power/torque going thru them....
if its any defence of them in all cases there customer service has been immense and problems fixed straight away...
Old Nov 28, 2012 | 11:51 AM
XRT_si's Avatar
XRT_si
Would defo go Supra if I had another Cossie.
As above, the Gripper (or Bara/Quaife etc...) all use the standard CWP. I broke a CWP on less than 400 bhp, so wouldn't consider an uprated diff that still used a standard CWP.
Old Nov 28, 2012 | 12:02 PM
SaphCos4x4_Dan
Hmm well I'm still unsure whether to keep the gripper or go for the supra..
What is a gripper worth?
And if I were to keep it where can I get a stronger cwp?
Old Nov 28, 2012 | 12:25 PM
XRT_si's Avatar
XRT_si
You can't get a stronger one, hence the problem with them. It's the physical size of the teeth that's the problem.
I think some companies do shot-peen them to help them last.
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
