what is good for removing bird s""t???
Old Nov 18, 2012 | 02:53 PM
fordsportjay's Avatar
fordsportjay
Default what is good for removing bird s""t???
as per title really......
park under a tree at work and roof is a bit messy
Old Nov 21, 2012 | 12:02 PM
opposite lock's Avatar
opposite lock
I use a Tar n glue remover to dissolve it (leave for 30-50 seconds on cured paint only) , hot water and a soft cloth . If its really bad you may need to keep flowing hot water over it to soften it up before trying to fully remove. Try the hot water first.
Old Nov 21, 2012 | 12:52 PM
martysmartie's Avatar
martysmartie
HOT water is a must, as above ^^, if you use cold water it wont remove it and you rubbing will scratch the paintwork!
I would soak first, then it should just literally fall away, and you can remove with a sponge etc.
Martin
Old Nov 21, 2012 | 01:16 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Remove it as soon as you see it. It can damage paintwork very quickly.
Old Nov 21, 2012 | 01:35 PM
SteveB's Avatar
SteveB
I normally soak a piece of kitchin roll and leave it ontop for about 10 minutes until its soft and wipe clean...
Old Nov 21, 2012 | 01:45 PM
pani_k's Avatar
pani_k
PassionFORD Member
Hot water as above or blast off with pressure washer.
Old Nov 21, 2012 | 03:57 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Lots and lots of water will break it down but it can fuck the paint within a very short space of time depending on what the bird has consumed
Apparently bird "lime" is a mixture of both piss AND shit and it's the piss that eats the paint
Old Nov 21, 2012 | 07:48 PM
disco-stu's Avatar
disco-stu
shot gun illiminate the problem completey
Old Nov 22, 2012 | 11:24 AM
opposite lock
No dont do that !
You could end up taking paint/clear with it.
Old Nov 22, 2012 | 11:26 AM
opposite lock
Be careful with the kitchen roll stuff it can be very abbrassive to the surface especially dry of course.
Old Nov 22, 2012 | 11:30 AM
pani_k's Avatar
pani_k
PassionFORD Member
Originally Posted by opposite lock
No dont do that !
I try nip it in the bud before it sets but I must admit I've done that on occasion with my old Focus. The ST hasn't been pooped on yet so will avoid blasting it!
Old Nov 22, 2012 | 12:05 PM
martysmartie
Correct, as pee is acidic, but there again I think poo is to an extent as well, I think.
Martin
Old Nov 22, 2012 | 12:10 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
Go out with a better class of girl
Old Nov 22, 2012 | 12:11 PM
Turbosystems
Super Moderator
Martin
I read that it wasn't the bird pooh it was the fact that the dried on bird pooh holds the acid rain
Old Nov 22, 2012 | 12:19 PM
davidfordrs's Avatar
davidfordrs
Default Bird shit
We use a heat gun at work obviously you need to take your time but it does work, we use it on jags, range rovers etc and it does the trick.
Old Nov 22, 2012 | 12:26 PM
atm's Avatar
atm
Yeah pressure wash it from 6 inches away like the local albanian carwash did to the gf's '06 mini cooper, taking the laquer with it and said naff all about it, only noticed it couple of days later!
Old Nov 22, 2012 | 12:27 PM
Turbosystems
Super Moderator
use olive oil to soften and remove it is the safest way
Old Nov 22, 2012 | 12:29 PM
phil_focus's Avatar
phil_focus
As others have said warm water pored over will get fresh stuff off easy but if its dried let it soak with a wet kitchen roll on then lift the kitchen roll and rinse with warm water.
Old Nov 22, 2012 | 12:32 PM
Turbosystems
Super Moderator
here's a link that says it;s nothing to do with the alkaline properties of pooh /wee
it's to do with the lacquer and heat and optical diffraction
the answer is to not let it dry wipe it off when it's fresh
http://www.telegraph.co.uk/motoring/...-your-car.html
Old Nov 22, 2012 | 02:19 PM
opposite lock
Interesting link , i,m wondering though say during the cold months that theory still 'sticks' excuse the punt , the expansion of the paints surface wouldnt happen but im reckoning if bird pooped on my bonnet but not removed sooner or later it,ll affect the area....or maybe not hmm
Olive oil , i will give that a go cheers Tony.
Old Nov 22, 2012 | 02:21 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
nitromors and a wire brush should shift it.
Old Nov 22, 2012 | 02:39 PM
opposite lock
Old Nov 22, 2012 | 02:52 PM
v man's Avatar
v man
Zee Germans are coming
That genuinely made me laugh
Don't know why just did
Can just imagine someone thinking " yeh that sound like it could work" and trying it
Old Nov 28, 2012 | 12:52 AM
White11's Avatar
White11
I use bug remover (kinda bubbles up and breaks it down) and wipe off always as soon as I see it!!
Old Dec 2, 2012 | 11:27 AM
slammedorion's Avatar
slammedorion
If it does eat in this is what we do at work, maybe a flat and polish to if really bad.
Old Dec 2, 2012 | 01:59 PM
v man's Avatar
v man
Club hammer and bolster for the really dried on stuff works good
Old Dec 2, 2012 | 02:43 PM
Brendan's Avatar
Brendan
struggling with reality
Autoglym active insect remover works for me! I also make sure it is HOT! before I put it on.
However I recommend a really good air rifle to discourage them from shitting on the car in the first place! Magpies and pidgins make HUGE ones, and if they have been eating the purple berries can take the paint off down to the bare metal (big thing on the Mazda forums)... my poor neighbor had this on his 1 year old car!
Old Dec 5, 2012 | 07:04 PM
jameswrx's Avatar
jameswrx
A scouring pad according to a bloke I used to work with! Oh, and my sister too
Old Dec 5, 2012 | 08:41 PM
smudger068's Avatar
smudger068
+1 (make sure its hot water) simple and dont cost anything
Old Dec 9, 2012 | 10:15 PM
Brian's Avatar
Brian
Could try this Poorboy's Bird Sh!t Remove http://www.waxamomo.co.uk/ecom-prodshow/pbbsr.html
Brian
markk
Dec 2, 2021 06:59 PM
Aug 29, 2015 08:16 PM
Ethan sagoo
Aug 25, 2015 03:22 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
