Cosworth engine co2 too high and temp gauge fault
Hi I dont know if anyone can help< my son has had his yb cosworth engines head rebuilt the vehicle all runs now but it has gone for an MOT and failed on emmisions, to much co2, it chuffs out black smoke and the plugs are sooted up when removed, have put new plugs in they soot up as well, have put in a new ect sensor but no joy,the temp gauge moves straight up to hot when ignition key is turned on with the engine not hot or running with the old sensor and the new one and with the wires of the sensor all together, this conversion has been put in a van anda very good job but dont know much about them myself, any ideas or what I should be looking at?
It could be multiple things, firstly do you know the software is correct in relation to the spec?
Best thing is to get it set up really as then you know your AFR etc is correct and gives you piece of mind.
Without knowing the exact van it's fitted to it's hard to say, I should imagine the wiring has shorted to ground, suffice to say it's nothing to do with the engine, that merely has a sender fitted to the head which is the ground for the standard temperature gauge.
The CO is adjustable, but you need a "exhaust gas analyzer" for this, plus this most likely is NOT the problem!
Martin
Martin
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
