Mk2escort grp4 cosworth conversion paul&si
Old Nov 3, 2012 | 09:03 AM
siscossie's Avatar
siscossie
3-door moonstone
Talking Mk2escort grp4 cosworth conversion paul&si
It's coming up to 3 years ago now we started this project so it's about time I started a resto thread. I've been putting pictures up now and again but will start from the beginning, if I can find all the pictures.
After we got the car home it was in a sorry state, some one had left a car battery on the roof that had leaked. You can imagine the mess that left, the door skins where nackered and the heater bubble had some real rust. So we removed the front wings and cut out the heater bubble
Then we cleaned up the inner wings they weren't too bad really
The previous owner had tried to repair the rear pillars which had rusted through after we got through all the filler this is what we was left with
This wasn't good so we sourced a pair of rear quarters and fitted them to replace the pillars
While we was doing that we also stripped the engine bay down to bare metal
Seam welded the chassis while we was in there and put strengthening plates in
Old Nov 3, 2012 | 09:12 AM
siscossie's Avatar
siscossie
3-door moonstone
We also got a spit to put the car on , the best bit of kit we've bought so far. Makes it so easy to flip over a and no more laying on the cold concrete floor in the garage
We also replaced the splash guards from the top of the inner wings
Then we started to clean the floor back to metal to see what we were dealing with
We also fitted a bigger diff tunnel to make room for the atlas axle that would be going on
Old Nov 3, 2012 | 09:27 AM
siscossie's Avatar
siscossie
3-door moonstone
We then started to fit the rear link boxes for the back axle, it was decided to 5 link the axle and to put coilovers in the rear too, so we had to fit turrets to mount the rear coilovers in
This is the chassis mount for one of the axle bars
This stops side to side movement
Front suspension all removed
Both rear wells had a bit of rust so it was decided to replace them, just start from fresh
Once they were fitted we had to cut some of the arch away to make room for the new rear wheel arches that we were fitting, colin McRae +2" was decided.
A new piece was welded in to make a new tub for the bigger wheels
Also while doing that welded some mounts in for the roll cage on the rear arches
Old Nov 3, 2012 | 09:34 AM
siscossie's Avatar
siscossie
3-door moonstone
Here's a pic of the rear turrets
Welded a strengthening box on each of the link boxes
After we had done the rear arches and all the link boxes we replaced the chassis rails on both sides for new ones and gave it a coat of primer
Then seam sealed all the jionts
Old Nov 3, 2012 | 03:04 PM
luke19790_3's Avatar
luke19790_3
Nice.
Old Nov 3, 2012 | 03:23 PM
andy escos's Avatar
andy escos
looking good so far keep it up .
Old Nov 3, 2012 | 04:00 PM
turbo m's Avatar
turbo m
Nice one will be watching this...
Old Nov 3, 2012 | 04:22 PM
coswurv's Avatar
coswurv
Love the mk2's, keep the pics coming.
Old Nov 3, 2012 | 04:42 PM
james kiely's Avatar
james kiely
great work chaps
Old Nov 4, 2012 | 09:34 AM
siscossie's Avatar
siscossie
3-door moonstone
The wings were refitted and a new front panel and a new rear panel
Roll cage to be cleaned and fitted
Rollcage fitted adding some extra bars
New door skins fitted
There were parts on the sills we weren't happy with so they were removed
Rear arches fitted and picked up some wheels but more on those later
Old Nov 4, 2012 | 09:44 AM
siscossie's Avatar
siscossie
3-door moonstone
Front arches and spoiler fitted
We removed the boot floor and raised it slightly to give more room for the exhaust
Old Nov 4, 2012 | 10:01 AM
adam151082's Avatar
adam151082
Awsome, id love a mk2
Old Nov 4, 2012 | 10:22 AM
matman's Avatar
matman
looking good
Old Nov 4, 2012 | 12:24 PM
siscossie's Avatar
siscossie
3-door moonstone
We had a go at refurbish one of the wheels, sanded the centres down then had a go at polishing the lips. Got a polishing kit off ebay took nearly 2hours on one wheel, don't think it came out too bad
Old Nov 4, 2012 | 01:19 PM
fezzajsy's Avatar
fezzajsy
looking good
Old Nov 4, 2012 | 02:40 PM
Zetecfiesta's Avatar
Zetecfiesta
Very nice!!!
Old Nov 5, 2012 | 03:38 PM
siscossie's Avatar
siscossie
3-door moonstone
So after all the body had been done or most of it anyway a coat of high build primer was added
Meanwhile we managed to get hold of two wheels for the rear same as what we had but in 10"/15" and a massive offset, they were still new and in good condition just need polishing.
Old Nov 5, 2012 | 03:58 PM
siscossie's Avatar
siscossie
3-door moonstone
Trial fitted mock up engine for first time
The down pipe was a bit close so we decided to give it a bit more room
Meanwhile this is the engine I'm building to go in the mk2, nearly there
Old Nov 5, 2012 | 04:03 PM
siscossie's Avatar
siscossie
3-door moonstone
Old Nov 5, 2012 | 04:08 PM
siscossie's Avatar
siscossie
3-door moonstone
We also got a Capri 2.8 injection back axle with LSD after welding all the brackets on for the link bars and the rear calliper conversion brackets we trial fitted it
Old Nov 5, 2012 | 06:59 PM
whizzisat114's Avatar
whizzisat114
Coming on well
Old Nov 6, 2012 | 10:18 AM
IveGotaCosworth's Avatar
IveGotaCosworth
Keep up the good work mate
Really cool project - and i must say the width of the rear wheels are megga
Old Nov 7, 2012 | 07:26 PM
steve st220's Avatar
steve st220
"SNIFF MY DIFF"
youre doing a great job there guys, love a nicely prepped mk2.
Old Nov 8, 2012 | 07:03 PM
siscossie's Avatar
siscossie
3-door moonstone
Cheers felas more updates soon
Old Nov 8, 2012 | 07:20 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Tidy project mate! Love mk2's
Old Nov 9, 2012 | 04:34 PM
turnover's Avatar
turnover
Coming along nicely ,keep up the good work
Old Jan 18, 2013 | 08:48 PM
Stw7's Avatar
Stw7
I'm glad I found how to to the down pipe now and could any one tell me if u need to mod the steering column be a great help as I'm in the middle of doing one my self
Old Jan 19, 2013 | 07:18 PM
siscossie's Avatar
siscossie
3-door moonstone
Not the column you need a grp4 steering knuckle small one
Old Jan 19, 2013 | 07:25 PM
Stw7's Avatar
Stw7
Thanks very much and how do I go about the wiring lol
Old Jan 19, 2013 | 09:08 PM
Cool project.I like it alot.
Old Jan 20, 2013 | 10:18 AM
siscossie's Avatar
siscossie
3-door moonstone
That's something that's just been started now will keep you informed
Old Jan 20, 2013 | 10:38 AM
BRAMMER's Avatar
BRAMMER
Proper cool
Old Jan 20, 2013 | 02:50 PM
fezzajsy's Avatar
fezzajsy
looking good
Old Jan 20, 2013 | 03:09 PM
Stw7's Avatar
Stw7
Sweet that would be great thanks
Old Jan 20, 2013 | 03:11 PM
rs clint's Avatar
rs clint
insane
looking good m8
Old Jan 20, 2013 | 04:11 PM
siscossie's Avatar
siscossie
3-door moonstone
Haven't done anything On the Escort For awhile but here's a few of the boot floor which has been chopped out and a new flat one welded in, and we made a tank base as well.
This is what it was like before
Old Jan 20, 2013 | 04:20 PM
siscossie's Avatar
siscossie
3-door moonstone
Engine bays been painted
Also the underneath is painted
Old Jan 20, 2013 | 04:28 PM
siscossie's Avatar
siscossie
3-door moonstone
Inner wings done
And the cage and interior
This is how the body sits so far
Old Jan 20, 2013 | 04:31 PM
siscossie's Avatar
siscossie
3-door moonstone
Intercooler and rad combi fitted
Old Jan 20, 2013 | 04:43 PM
Stw7's Avatar
Stw7
Wow she's looking really smart
