Mk2escort grp4 cosworth conversion paul&si
Old Sep 27, 2016 | 01:46 PM
  #241
siscossie's Avatar
siscossie
3-door moonstone
cheers fela
Old Sep 27, 2016 | 02:40 PM
  #242
costina's Avatar
costina
Live long and prosper!!
Do you make the covers Si ?
Old Sep 28, 2016 | 02:36 PM
  #243
siscossie's Avatar
siscossie
3-door moonstone
Yes fela I do
Old Nov 6, 2016 | 12:45 PM
  #244
siscossie's Avatar
siscossie
3-door moonstone
Back on the loom today not far off now, with the waisted spark in it aswell
Old Jan 14, 2017 | 05:43 PM
  #245
siscossie's Avatar
siscossie
3-door moonstone
Back o the car today after a xmas break we got the loom finished and also mounted the brake reservoir tank, just need to polish it up now
Old Jan 15, 2017 | 03:46 PM
  #246
siscossie's Avatar
siscossie
3-door moonstone
Got both the header tank and the brake res fitted up also the ignition pack mounted
Loom finished just tanks to polish up
Size:  1.79 MBcom/user/siscossiers500/media/image_22.jpeg.html]Name:  image_22.jpeg
Old Jan 17, 2017 | 07:37 PM
  #247
tjRS500's Avatar
tjRS500
Where did you get the braiding for the loom?
And the rubber finishes for the ends of the plugs ? The injector plugs etc I think ?
Old Jan 18, 2017 | 12:11 PM
  #248
siscossie's Avatar
siscossie
3-door moonstone
You can buy the plugs and rubber boots off ebay fela and the braiding aswell, brand hatch performance do most of it aswell
Old Jan 28, 2017 | 06:05 PM
  #249
siscossie's Avatar
siscossie
3-door moonstone
Today we started to fit the handbrake cable and the mountings for the adjuster brackets, the cable is off the cossie with it having the 2wd rear caliper setup.
need to weld some mounting brackets onto the axle brackets to secure the cable in place will get some pics up tomorrow
Old Jan 29, 2017 | 03:06 PM
  #250
siscossie's Avatar
siscossie
3-door moonstone
New fittings for the vac pipes and breather pipe valve gone into the inlet manifold
Old Feb 12, 2017 | 12:43 PM
  #251
siscossie's Avatar
siscossie
3-door moonstone
So we decided to change the clutch for a helix 6 paddle same as whats in my 3dr so it will cope with the power ok with no issue, got it from matt lewis again and fitted it today
Also decided to go hydraulic clutch aswell, but as we already have a peddle box we are converting it so it will take the hydraulic version
as it is now
and with the new piece fabricated and ready to weld on
Get this welded on then we have to modify the peddle aswell
Old Feb 12, 2017 | 06:51 PM
  #252
Caddyshack's Avatar
Caddyshack
Lovely
The head looks really close to the bulkhead, is there room for engine movement?
Old Feb 13, 2017 | 04:38 PM
  #253
siscossie's Avatar
siscossie
3-door moonstone
Yes there's a bit of room but the engine is on rock solid mounts so cant move much anyway fela
Old Feb 17, 2017 | 05:39 PM
  #254
siscossie's Avatar
siscossie
3-door moonstone
Got the peddle box welded up tonight still needs painting and tidying up but looking good
Next is the new nose for the gearbox and fitting the new bottle for the fluid
Old Feb 20, 2017 | 04:50 PM
  #255
siscossie's Avatar
siscossie
3-door moonstone
Put some heat reflective matting in the engine bay last night
Old Feb 28, 2017 | 06:48 PM
  #256
siscossie's Avatar
siscossie
3-door moonstone
Made a plate for the bulk head where the pipes will pass through into the engine bay for the brakes and the clutch
Old Feb 28, 2017 | 07:01 PM
  #257
Them pipes are a good idea.
Old Mar 1, 2017 | 05:59 PM
  #258
jonfoc's Avatar
jonfoc
Cracking project. What size master cylinders are you using for the front, rear and clutch?
Old Mar 2, 2017 | 05:38 PM
  #259
siscossie's Avatar
siscossie
3-door moonstone
We have decided to get a new brake res with 3 pots so it will have one for the hydraulic clutch aswell so the other one is for sale on ebay
will find out the sizes fela
Old Mar 2, 2017 | 05:50 PM
  #260
siscossie's Avatar
siscossie
3-door moonstone
front 0.65
rear 0.7
clutch 0.7
Old Mar 31, 2017 | 07:28 PM
  #261
siscossie's Avatar
siscossie
3-door moonstone
Now we have changed the brake reservoir for a 3 pot one to accommodate the hydrolic clutch we fitted the bulk head plate and made the pipes up
We're very happy think it looks pretty good sorted fela far
Old Apr 3, 2017 | 09:10 AM
  #262
DaveCrack's Avatar
DaveCrack
Very neatly done and great attention to detail! Love it!
Old Apr 3, 2017 | 01:50 PM
  #263
rooos's Avatar
rooos
same...
Old Apr 5, 2017 | 04:41 PM
  #264
siscossie's Avatar
siscossie
3-door moonstone
cheers fela
  #265
siscossie's Avatar
siscossie
3-door moonstone
Originally Posted by rooos
same...
thanks bud
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
