Canbus error?
Old Oct 23, 2012 | 09:26 AM
northernmonkey's Avatar
northernmonkey
I didn't do it!
Default Canbus error?
I'm pretty sure I've already convinced myself about this but would like a bit of reassurance
I acquired a little 1.4 petrol fusion 2 that had a small melt of the engine loom wiring, after replacing the loom I found that it was only firing on 2 cylinders, I then replaced the coil pack only to find out it had spiked the ecu. :-/
I sent the ecu of to the ecu doctor, who replaced the output and coil drivers, it came back, we plugged it in and the car ran lovely, however....
I have no speedo and the mileage display just shows dashes, it was working previously as I have seen the odometer reading.
When plugged in, the car is showing a 'can bus' error. Rob at the ecu doctor seems to think that there would be lots more not working if that was the culprit.
Now after a quick google, many people think that the vss causes this too, and indeed the abs module (not even sure it has abs!) but it does seem strange that its gone down since the ecu was repaired (the car hasn't moved in between)
Your thoughts?
Old Oct 23, 2012 | 10:29 AM
johnny99's Avatar
johnny99
CAN BUS error where, you need to get a propper diagnostic done before you spend more money. It's possible the spike done more damage than the ECU.
John
Old Oct 23, 2012 | 10:42 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Can bus is just a loop of wire that loops in and out of each ecu on that can network via a resistor in each ecu! If you no what the resistance of the cannet work should be its an easy check with a multi meter to see if its ok
155lee
Oct 27, 2015 04:55 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
ST-170
Sep 4, 2015 11:02 AM
Cragrat
Sep 2, 2015 08:25 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
