cvh ignition timing setup
Old Oct 22, 2012 | 03:02 PM
silkmead's Avatar
silkmead
Default cvh ignition timing setup
hi guys at what rpm should the ignition timing be setup at with the vacuum advance not connected, its on a 1.6cvh race engine ?
Old Oct 22, 2012 | 09:49 PM
silkmead's Avatar
silkmead
anyone ?
Old Oct 22, 2012 | 10:05 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you say race engine, but what exactly has been done?
what fuel is it running on and at what point do you hear pre ignition?
all the above means bugger all, just like to ask questions lol!
basically you want to advance it enough to make power and not generate high egt's, but not too far as this can cause pre ignition and melt the engine.
just tweak with it till it's right, but the fuelling will need adjusting to match altered timing.
there is good reason why many would suggest visiting a tuner as they have the experience and equipment to get the best from it in most cases.
Old Oct 23, 2012 | 11:31 AM
haz87's Avatar
haz87
If its a race engine then you should have/get your dizzee recurved to suit the engine anyway. Standard dizzees aren't 'all in' till about 4.5k and you want it alot earlier than that really.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Ben26
Aug 27, 2015 08:56 PM
Zoggon
Aug 10, 2015 10:39 AM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
