General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Been on mine for many years the diff will be a 3.54 i expect but check out the tags . One tag will give diff ratio & the other say PL if the diff is Power Loc.
Ive done a search on here and there appears to be mixed feelings about them, but not always from people who have had the setup, so keen to get views from people who have had / still have them fitted.
What's it like to drive with? Does it make the back end feel more planted?
Thanks
I think the accleration figures for my car speak for themselves with Power Loc grip is immense. Ive had a quaife & you cant compare the two.
One of the first Jag conversons was done to a Sierra in approx 1988, it was for a budget car to compete against the cost of the works items.
I bought the beam and diff from that car in 1998, it was built on the original XJS type not the later item, though the diff units are the same power loc units.
The later conversion i.e as in Rods car was inspired from when my own car was seen by a few on this forum .
My conversion worked on the oe shafts, so no makiing new shafts, the conversion is very cheap tbh and works very well, if its put together correctly.
See this is where it gets difficult, as Rods car is testament that it can't be that bad, as I don't think I'd fancy doing 200mph with a rear setup I didn't trust.
Out of interest Rod, is yours the tubular arm setup?
Not difficult mate what you must understand is its my car for a minority everything thats fitted to it is shite, they are experts im not . These guys earn there living being Cossie experts so I have to except they know best well untill it comes to creating a fast car .
rods car proves how good it can work, i wouldnt hesitate to have it if i had a big power cossie, the whole conversion would be much cheaper than just one of those 10" ford diffs wouldnt it ? before i get shot in flames im not 100% sure it is 10" but the proper diff iirc was it the one they used in btcc ? mega money diff like Ł4000 odd ?
9" Ford you mean. Don't think anyone is slating having a Jag diff conversion, just a ZOO beam!
nothing wrong with a ford 9 inch or jag diff just the zoo beams we have seen
but they were just 6 degree ones with std diffs
horrendous fabrication and welding
one particular one we checked for a guy the arms wouldn't move
we had to issue a section 58
