1959 Ford Anglia 100e
Here is my first ever complete restoration, hope it is of interest to people!
Car got delivered on Sat, the car was missing some bits of trim, door handles, front 1/4 glass and bits and bobs.....or so I thought!
Opened the boot to find a small auto-jumble! Most the missing trim plus a few extras.
Seats are pretty tidy and I like the colour, just need a clean and frame rubbing down and painting.
Some of the parts from the boot...
Had a tidy and sort out to make room for the strip down
From this
To this
Today I had a bit of a planning day, got some storage unit, had a good clean of my garage and a sort out so that i'd have room for the car and panels with room to move! Due to the garage not having power I picked up a petrol generator to run a drill and angle grinder off. Plan is to do most the body work and prep in this garage then once ready for the welding move it to a workshop down the road and do it all in one hit.
Few photos of the underside
Doesn't look to bad, was expecting worse!
Started stripping off the doors, bonnet boot.
Then moved onto the front wings and grill.
The car has obviously had some work in the past, most parts were pretty solid. I'm a bit of a virgin with cars of this age so what do people think? Tomorrow I plan to start taking back the surface rust and paint to see what's left. Have had a poke about the floors and sills and all feel pretty good.
That's about it for now, hopefully will crack on with the shell tomorrow, sanding back and looking into getting the engine and 'box out.
Any comments, advice or observations/info welcome! One thing I was wondering was where is the battery tray!?!? Has it been removed and where from!?
From this
To this
cracking car hope the colour is going ,save ur self alot work an get it blasted soda blasting isnt that much now ,or make a spit and get some wire wheels for the grinder
I will see what companies are down this way, I am in far west Cornwall so bit out in the sticks! Will have a crack by hand first anyway to develop my skills, and in a way I want to do it by hand as much as possible. In no rush so will keep me busy in my spare time!
Stripped the shell of all apart from the rolling gear, had it up on the ramp today down at the workshop, looked pretty good underneath!
Am working panel by panel, first up was drivers floor pan, grinded down, treated and first coat of primer on. I'm not too bothered about a perfect surface finish on the floor as will have carpet in.
Had to have a re shuffel of the garage so car could go in the middle on axle stands
Will hopefully get some photos of the underside on later.
The engine is shot and have never seen the gearbox working. If anyone has a known running and working standard engine and box please drop me a message.
Engine and box out
Underside
Looks pretty solid, will remove all the orange paint, see that it is good, treat it and paint it with some chassis black paint.
Underside
Once I have taken all the suspension, rear axle etc etc off so it is a bare shell, would it be ok to put the shell on its side? Make it easier to do the underside. Or can this distort the shell?
I think plans for now are to remove all rust from body and get it treated and primered before I go back to Afghan late Nov. Will make the real plan up for when I get back. May just stick with original engine and keep the car standard/period.
Billy_RS
16
Oct 11, 2025 09:41 PM
borboyous
Aug 22, 2015 11:17 AM
