Pull type slave cylinders.
Old Oct 12, 2012 | 03:16 PM
Chopshop85's Avatar
Chopshop85
Default Pull type slave cylinders.
Does anybody know of any cars that came with these?
Old Oct 12, 2012 | 06:39 PM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Old type imprezas had pull clutches... Not heard off a pull slave though I'm not sure how that would work.
Dan
Old Oct 12, 2012 | 08:44 PM
stevieturbo's Avatar
stevieturbo
C**t
As above, just because it has a pull clutch, doesnt mean the slave pulls.
Although for some reason I have it in my head some Porsche stuff might.
But normally all slave's or hydraulics only push
Old Oct 12, 2012 | 08:54 PM
Greasenuts's Avatar
Greasenuts
some french shit
pug 406 for sure
Old Oct 12, 2012 | 08:59 PM
stevieturbo
C**t
Originally Posted by Greasenuts
some french shit
pug 406 for sure
Googling they look like a very normal push slave ?
Old Oct 12, 2012 | 09:07 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
http://www.ebay.co.uk/itm/Wilwood-Pu...item5aea48f46f
Im using one of these on my MTX75.
Old Oct 13, 2012 | 12:31 AM
Chopshop85's Avatar
Chopshop85
Cheers for the replies!
After much searching its "pull type clutches" not cylinders, there are certain r33 skyline parts listed as pull type clutch cylinders, however this is the way the clutch operates, not the cylinder.
Minirotty - Thats what I have gone for, the only reason I was looking else where was because the website I saw the willwood one on had the dimensions all wrong and it sounded way to big for the application.
Old Oct 13, 2012 | 08:27 AM
stevieturbo
C**t
So it's a pull type clutch you're after now ?
Size ? diameter ? power ?
Old Oct 13, 2012 | 09:09 AM
luke19790_3's Avatar
luke19790_3
i'm using that wilwood one too
Old Oct 13, 2012 | 09:43 AM
orionmojo's Avatar
orionmojo
Rally design sell lots of stuff like this.
Old Oct 13, 2012 | 12:29 PM
Chopshop85's Avatar
Chopshop85
No still just the pull type slave. Ordered the wilwood one.
do you have any more pictures of your set up?
yeah as far as I know its only rallydesign that sell them in the uk
Old Oct 13, 2012 | 01:32 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
You can also use Master and push like this on Jon Williams/Nathan Steels Fiesta, I believe CrazyCage made it?
Old Oct 13, 2012 | 02:17 PM
crazycage's Avatar
crazycage
the one above is nice
Old Oct 13, 2012 | 03:01 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
You got any brackets made for MTX75 bud?
Old Oct 13, 2012 | 03:07 PM
Chopshop85's Avatar
Chopshop85
I was using a push type after being inspired by Karlos's conversion thread. Got it all plumbed up and working yesterday morning, well chuffed. However, being the numpty I am I neglected to realise that most the people who have done the hydraulic conversion on an ERST are running efi!
Started putting the car back together to discover the metering unit sits about an inch in front of the clutch arm right where my new bracket and slave cylinder are!
So pull type it is.
Old Oct 13, 2012 | 03:12 PM
crazycage's Avatar
crazycage
no mate , most people just fit the focus rs box and its hydraulic anyway.
i done a kit for stu colins when he was still running the ib5 box and snapping clutch cables for fun lol.
he said it only needed a small tweek to fit his rs2k gearbox but you would have to ask him to be sure .
Old Oct 13, 2012 | 04:38 PM
M K's Avatar
M K
Here is how I done it on my old xr2, best pics I've found but probably better ones somewhere
Old Oct 13, 2012 | 04:50 PM
luke19790_3
shouldn't it be fitted the other way around to make bleeding easier?
Old Oct 13, 2012 | 05:49 PM
Greasenuts's Avatar
Greasenuts
Yep, my bad, The slave works conventionally, but, the release bearing actually pulls the clutch "fingers"!!!
Weird and completely french!!
Old Oct 13, 2012 | 08:18 PM
crazycage's Avatar
crazycage
its a oe cylinder and thats how it is fiited on the standard cars.
never had a problem bleeding them.
Old Oct 14, 2012 | 01:00 AM
Chopshop85's Avatar
Chopshop85
Cheers for the pics. I never though about running the cylinder through the clutch cable hole. Looks smart.
Old Oct 21, 2012 | 11:53 PM
Chopshop85's Avatar
Chopshop85
Ok so got my wilwood pull slave fitted and working. However, I have a question. Will using a larger master cylinder give me more travel on the slave?
I'm only getting around 20mm travel on the clutch arm. IIRC it travelled about 30mm when using the cable.
Old Oct 22, 2012 | 10:14 AM
stevieturbo
C**t
Yes a larger bore master will give more travel at the slave.
or you could just alter the pivot points somewhere to give you more travel at the master ( assuming there is some left )
Or alter where the slave acts so the 20mm may be enough.
Old Oct 22, 2012 | 12:17 PM
Chopshop85's Avatar
Chopshop85
Cheers.
It may work as i've not got the car back together yet to start and test it, I just wanted to know if that was an option.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
