no power to fuel pump on a saff cossie
Old Oct 9, 2012 | 08:35 PM
slider's Avatar
slider
Default no power to fuel pump on a saff cossie
i picked up my first cossie on sunday, ita a 1991 4x4 but only has 2wd, the fuel pump has been bodged wired to an ignition live to get it running but i want to correct it and fix the fault, ive got a good earth, inertia switch is ok but i have no power to the pump, where is the pump relay? is there a seporate fuse for it?
ive checked all the fuses in the main box under the bonnet just wondered if there is a second one hidden somewhere
thanks
Old Oct 10, 2012 | 09:18 AM
opposite lock's Avatar
opposite lock
Not sure on 4x4 but on a 2wd the fuses/relays are behind the glove box area.
Old Oct 13, 2012 | 06:42 PM
slider's Avatar
slider
same place thanks m8, no relay in the base which is why it had no power
ekjim
Aug 27, 2015 05:20 PM
Adam-M
Aug 26, 2015 05:53 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
