ST170 ABS Light issue
Old Oct 5, 2012 | 05:16 PM
Gav Diamond's Avatar
Gav Diamond
Default ST170 ABS Light issue
Hi Guys
Recently changed a wheel bearing on my St170 and Euro Car Parts had given me the incorrect bearing so the ABS/Traction light can up.
I have got another bearing from them and fitted it today (I put the black ring (that was also magnetic) on the inside by where the sensor goes).
I took the car for a run up the street and now when you first start the car and pull away the lights go out but then soon as you get to about 20mph the lights come back on..
Do I need to take the car to a garage to get the code deleted or do I still have a problem as the lights should just stay off?
Thanks
Gavin
Old Oct 5, 2012 | 09:31 PM
RichieST's Avatar
RichieST
The light should go out, I had a similar issue on my mondildo, put a new sensor in and the light went out straight away.
Old Oct 6, 2012 | 02:47 AM
Gav Diamond
This is the thing, the lights do go out and stay out until you go over 20mph which is the bit I don't understand.
Will have to get the car to somewhere that can plug it in and not charge me the earth for the privilage.
Wish the Fords had something like the VW's do with Vag-Com so I could do it myself...
original
Apr 28, 2026 05:20 PM
Bailes1992
Sep 3, 2015 02:17 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
rdvil
Aug 15, 2015 12:11 PM
