How much power and boost can zetec rods take?
Old Sep 19, 2012 | 09:03 AM
escortrss1300bhp's Avatar
escortrss1300bhp
Default How much power and boost can zetec rods take?
Any clue
Old Sep 19, 2012 | 09:11 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
some say 300bhp or relative torque more to the point.
i have run 23psi through a 1.8 zvh from a 4wd cos turbo and didn't damage rods after years of abuse.
Old Sep 19, 2012 | 09:24 AM
escortrss1300bhp
O as One of my rods bent had water go in oil too
Old Sep 19, 2012 | 09:43 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
water in oil, are you sure the head gasket wasn't on it's way out and hydro locked the engine on one cylinder and bent the rod that way?
rod failure on it's own isn't likely to damage the water jacket unless the rod goes through the block or mangles the head gasket if the piston cracks and falls apart.
Old Sep 20, 2012 | 06:23 AM
escortrss1300bhp
The head gasket only did 2500 k and was a felpro wen it went it bent and smashed a bit of the piston cylinder at bottom
Old Sep 27, 2012 | 12:25 PM
forevaford's Avatar
forevaford
mines running 20 psi and close to 300bhp, and had lots of abuse with no ishues. only revs to 6.5 k tho
JK12
33
Apr 26, 2021 12:09 PM
markk
Sep 9, 2015 08:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
