16v in to a sierra
Old Sep 8, 2012 | 11:17 AM
orion turbo's Avatar
orion turbo
Default 16v in to a sierra
as title i am in middle of putting a 2.3 16v scorpio engine in my sierra. sierra is already a twincam one so plumming isnt a problem. im going to be running weber 45s with rs2000 cams and custom 4 branch. my problem is what to do with the ignition side of things?? . these engine run twin coil packs is there any thing i can do as the whole car ment to be a budget drift toy.
what module do i need to retain the scorpio to run just ignition. a mate recomended msd or megajolt???
Old Sep 8, 2012 | 11:30 AM
dojj's Avatar
dojj
Resident Wrestling Legend
aftermarket if you want to get the ignition side of things working
pretty simple with just a trigger wheel for the cps being already built into the side of the block near the oil filter so you should be good to go
Old Sep 8, 2012 | 11:36 AM
orion turbo
what would you recommend. can you link me to somewhere that already done this conversion?
Old Sep 8, 2012 | 12:03 PM
dojj's Avatar
dojj
ford power forums mate, plenty of folks there who have tampered with this sort of stuff
Old Sep 8, 2012 | 06:37 PM
orion turbo
is there any off the shelf 4 branch for a rwd mounted 16v
also whats preferable for ignition
msd
megajolt
or
omex
Old Sep 8, 2012 | 06:47 PM
dojj's Avatar
dojj
megasquirt seemed to be favorite for ease of use
i've got a dohc and a 2.3 exhaust sitting around in the garage so i'll find out if they share the same bolt pattern
from what i can see they do, but i may be wrong so won't quote me on that
plus i'm enjoying some falling over juice
Old Sep 8, 2012 | 08:32 PM
mothrs2k's Avatar
mothrs2k
Cant you just use an edis-4 module and early rs2000 pre-pats ecu and loom?? That way youl have fully working ignition
This way You can also get rid of the twin coilpacks and convert to single coilpack (from a fiesta turbo/escort zetec), for reliability purposes. Ive just done this to my engine and its made a diffrence with it not misfiring all the time due to getting rid of the baked wiring and coilpacks.
Old Sep 11, 2012 | 02:04 PM
orion turbo
iv been looking at the omex 200 ecu package . any body used this one before???
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
