Car will not start
Old Sep 7, 2012 | 02:56 PM
cherle's Avatar
cherle
Default Car will not start
Hi
Hope someone can help.
I have a ford focus 1.8dtci 2004, went out to it and it wouldn't start, so charged up the battery still wouldn't start changed the starter motor last night started fine three time. Went out this a.m and it wouldn't start again.
Any help would be great guys.
Cherle
Old Sep 7, 2012 | 08:20 PM
saph_Al's Avatar
saph_Al
Is the battery holding a charge ? . What noise are you getting when you turn the key , does it turn over but not start or just click ?.
Old Sep 8, 2012 | 06:22 AM
cherle's Avatar
cherle
Default focus non start
Hi
Its Just making a clicking sound.
Thanks
Old Sep 8, 2012 | 07:34 PM
saph_Al's Avatar
saph_Al
Chances are it's the battery thats had it and won't hold it's charge . Just have a check that nothing electrical is staying on when it shouldn't be ( ie boot light glovebox light ect). You need to get the battery drop tested and check that the alternator is supplying above 13v . I think halfrauds should beable to test both for you for a small fee if not for free. I assume the battery light isn't on all the time ever when the engine is running ?
Old Sep 9, 2012 | 06:40 AM
cherle's Avatar
cherle
Unhappy focus non start
Hi Al,
Its not the battery as I tried the oe of my puma on yesterday and it still has nothing.
Regards
cherle
Old Sep 9, 2012 | 10:45 AM
saph_Al's Avatar
saph_Al
Sounds like u may have a dud started or its not engaging and spinning . Was it a new or secondhand part ? .have you tried putting 12v to the exciter wire on the solinoid on the started to see if it spins the motor
Fordmad!
Sep 26, 2015 05:24 PM
Adam-M
22
Aug 10, 2015 10:46 AM
xr_craig
Aug 7, 2015 06:00 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
