Any ideas (my focus)
Old Aug 23, 2012 | 07:42 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default Any ideas (my focus)
Hi all, some will know I've just had my engine rebuilt also change turbo and manifold spec.
My problem is since the car has been on the road it won't start once warm?
It just cranks over and over but won't fire, the strange thing is it will bump start. I've changed crank sensor and cam sensor, I've tried running the car with the coolant temp sensor unplugged but still no joy. Now I can't remember before but now my fuel rail is pretty hot and I'm wondering if the fuel is evaporating but why would it bump start.
I want to get the car back to mad for a new mapping session but would rather try get this issue sorted first.
So any ideas please
Old Aug 23, 2012 | 07:47 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
how's the fuel system hooked up? could it be vapour locking the fuel rail?
Old Aug 23, 2012 | 07:54 PM
slammedorion's Avatar
slammedorion
Is the starter motor winding over quick enough once warmed up?
I know some cars wont fire if there not cranking over quick enough.
If not maybe some wiring braking down once warm?
Old Aug 23, 2012 | 07:59 PM
Dicko&Vacant
That's what someone said mate, but it's the same setup I had with last engine and turbo etc. Just can't understand why it's doing it now
Old Aug 23, 2012 | 08:01 PM
Mark Shead's Avatar
Mark Shead
Have you sorted your 0volts on cranking as this will be it.
Mark
Old Aug 23, 2012 | 08:06 PM
Dicko&Vacant
I've changed them fuse holders mark, going to pop back to Justins and plug laptop in again.
Old Aug 24, 2012 | 01:54 PM
gingeRS's Avatar
gingeRS
have you got a healthy fuel supply.
when my car is below 1/4 tank it will struggle to start from cold (but not from warm)
Old Aug 24, 2012 | 04:43 PM
v man's Avatar
v man
Zee Germans are coming
Just get the fucking thing to sheedy let m sort it for you once and for all
I'd have burt the thing out by now
Old Aug 24, 2012 | 05:53 PM
vroooom ptssssh
It Wasnt Me!
Told you to swap me it when it needed the engine sorted
Old Aug 24, 2012 | 05:56 PM
Dicko&Vacant
Pretty sure you said that about the cossie as well lol
Old Aug 24, 2012 | 06:13 PM
vroooom ptssssh
It Wasnt Me!
Haha, well you should have listened to me then, and you should listen to me now! lol
Rsmat
63
Sep 25, 2015 12:11 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
