SW England This is where members from the South West of England can arrange their meets and chat together.
Big Cossy problem
Old Aug 21, 2012 | 06:46 PM
cosworth it's Avatar
cosworth it
Default Big Cossy problem
Hi there,
Please help me someone!!! I have a Sapphire cossy 4x4, iam having majoy running problems with it. i used to be able to drive round for an hour or two without a hitch then all of a sudden it will lose power and die on me then won't start till it's cool down a little. some times just cuts out on idle but now won't start at all. when i put the ingnition on i can here the coil and injetor number 2 fires by it selves with out turning the engine over???? i thought it could be the loom witch i have now changed with no joy could be ECU maybe?? any surgestions??? (i have renewed all sensors)
Regards Mikey
Old Aug 21, 2012 | 07:09 PM
Nick.W's Avatar
Nick.W
Sounds like the ecu mate, mine was doing the same when I had an encryption fault with a chip that was sent out to me. Engine wouldn't fire and all you could hear where the injectors pulsing.
Another thing worth checking are the multi plugs located on the bulkhead behind the engine as these corrode and can cause all sorts of weird and wonderful faults.
Old Aug 21, 2012 | 07:14 PM
booner999's Avatar
booner999
where is Somerset are you?
Old Aug 22, 2012 | 07:43 AM
Stu @ M Developments's Avatar
PassionFords Creator
Sounds like a bad connection with the baby board ribbon cable.
Take ecu lid off with engine running and move the cable about to see if that replicates the problem.
Old Aug 22, 2012 | 05:36 PM
cosworth it
Hi all,
Yea i think it is the ECU as well, i have changed the loom for a better one as the wiring was knackered but didnt fix the problem, i can't start the engine anymore it just turns over now, i live near Burnham-on-sea
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
41
Aug 21, 2015 06:47 AM
Blown Hell
Aug 5, 2015 07:22 AM
