Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Compressor size for airtools/ spraying at home
Old Aug 16, 2012 | 08:56 PM
slammedorion's Avatar
slammedorion
Default Compressor size for airtools/ spraying at home
What size compressor will run airtools/ spraying at home, currently got a cheap 25litre compressor.
Fine for odd spray jobs, will cope with a air ratchet just!
But looking to upgrade so I can use airgun without tank wanting to refill every 2 seconds!
Won't be used everyday, but just wanna use airtools on DIY jobs now, getting lazy in my old age. 30 lol
Old Aug 17, 2012 | 08:16 AM
Turbosimpsons's Avatar
Turbosimpsons
min. 150ltr tank. 3hp motor, 11-13 cfm.
Old Aug 17, 2012 | 09:02 AM
SMILER258's Avatar
SMILER258
What sort of spraying jobs? Parts? Or a whole panel/car?
My dad has a 200 litre 2.5 hp compressor and that can spray and do jobs quite happily.
Although we want to upgrade to the biggest we can get.
Old Aug 17, 2012 | 07:07 PM
drive me crazy's Avatar
drive me crazy
Default compressor needs
depends on how much money and space youve got 100 ltr 14cfm is ample for running most air tools twin cylinder pump up faster ,and fit into the corner of garage.air chisels and D A sanders need alot of air, for diy occasional use, if you are going to to use it a lot ,150ltr static belt drive single are designed to last 12 cfm or above .get a machine mart catalogue you can compare the different specs be wary of second hand usually sold when coming to the end of life. you dont need a huge amount of air for spraying 40-50 lbs you can get low pressure spray guns run at 20 -25lbs
Old Aug 18, 2012 | 06:31 PM
dakar's Avatar
dakar
very good advice there
Old Aug 24, 2012 | 08:39 PM
MrJayware's Avatar
MrJayware
Im using the same size compressor and i painted my whole car in it no problem and its always fine will air tools under pressure
Old Oct 28, 2012 | 09:28 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
what the smalllest size compressor to allow me to spray the odd panel here and there?
a 12cfm 150 litre beast takes up a lot of space which I don't have!!!
Will i get away with something smaller if its just occasional use rather than daily spraying?
Old Oct 30, 2012 | 08:30 AM
saph4be's Avatar
saph4be
I have a 100 litre 5.5 hp petrol driven one in my van and my mate used it to spray a car no probs!
Old Nov 1, 2012 | 07:50 PM
Cossy Mike's Avatar
Cossy Mike
Got mine from machinemart for Ł300
100 litre 3hp 14cfm
Paint gun runs off it no problem at around 30psi
Air tool are fine also
Old Nov 1, 2012 | 10:50 PM
daz1968's Avatar
daz1968
I am in a similar situation and will go for a 3hp belt driven one with at least a 100 litre receiver. Even that isn't good enough if I go for an airfed mask but still got a small 1.5hp one so will probably use the two when spraying.
Old Nov 13, 2012 | 05:39 AM
suny's Avatar
suny
Nice post. I like it. Thanks for sharing these information. Keep it up.
Old Nov 13, 2012 | 08:03 PM
MrJayware's Avatar
MrJayware
I sprayed my whole car with primer and my 25litre compressor was fine
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
boeb
Jan 9, 2020 05:11 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
rsguy
44
Sep 29, 2015 03:29 PM
